Posts: 97 Joined: Thu Jul 21, 2011 8:22 am
Post
by TKrauss » Thu Mar 01, 2012 4:49 pm
After installing XE2 Update 4 on my Windows 7 x86 machine as standard user I get following error on every package:
[C++ Error] TCTargetsXE2.targets(446, 5): MSB6006 "mtbcc32" wurde mit Code 1 beendet.
<Target Name="TCPerformLink" DependsOnTargets="_ResolveOutput;_CheckLinkDependencies">
<TCLink
Condition="'$(TLibLink)'!='true' And ('@(OutputOutOfDate)'!='' Or '$(ForceLink)'=='true')"
ProjectFileName="$(MSBuildProjectFullPath)"
After clicking it shows the <TCLink line...
What is going wrong there?
Thank you!
Posts: 2212 Joined: Wed Oct 08, 2008 12:23 am
Post
by jomitech » Fri Mar 02, 2012 9:01 am
"mtbcc32 exited with code 1" means that mtbcc32.exe (the TwineCompile C++ compiler executable) failed. Do you get any other errors in the console log?
Post
by TKrauss » Fri Mar 02, 2012 11:55 am
If I try to compile with jtmake there is following output:
Target MakeObjs:
Target _PasDepCheck:
d:\WPS3\Entwicklungsumgebung\Source\wps3.cbproj wird übersprungen
Target TCCompile:
C:\Program Files\JomiTech\TwineCompile\mtbcc32.exe -ide2012 -dep -priority
JomiTech TwineCompile 3.3 - Copyright JomiTech 2011. All Rights Reserved.
Compiling 355 files...
Starting executors...
Couldn't compile files. Message: Timeout waiting for executors to start.
With admin rights I get madexcept log. I tried to attach, but txt and log are not allowed extensions?!?
So I zipped the log file...
madexcept.zip
(4.68 KiB) Downloaded 4420 times
Post
by jomitech » Fri Mar 02, 2012 12:10 pm
Are there any mtbcc32CompileExecutor.exe processes running? If there are, kill them, then try again.
Regarding the upload, we only allow zip files to be uploaded.
Post
by TKrauss » Fri Mar 02, 2012 4:52 pm
I tried again, but they are crashing with the same call stack in madExcept...
Post
by jomitech » Fri Mar 02, 2012 5:08 pm
If you run with administrator rights, does it succeed?
Post
by TKrauss » Sat Mar 03, 2012 6:18 am
The madexcept logs are under admin rights.
Under normal user rights there is no output in console...
Post
by TKrauss » Sun Mar 04, 2012 10:56 am
I now reinstalled Update 3 because I had other problems too..
But there I can't compile too. Same error same logs!
Something is completely wrong in my system. How can I completly remove TwineCompile? Which systemfiles and regkeys do I have to delete manually?
Post
by jomitech » Mon Mar 05, 2012 8:49 am
Run the TwineCompile un-installer (via Add/Remove programs in Control Panel). It will remove all the TwineCompile files and registry settings.
You can then delete the following items:
- The TwineCompile Program Files directory (usually C:\Program Files (x86)\JomiTech\TwineCompile)
- The TwineCompile Users directory (C:\Users\<User Name>\AppData\Local\TwineCompile)
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\JomiTech\TwineCompile or
- HKEY_LOCAL_MACHINE\SOFTWARE\JomiTech\TwineCompile if you're on a 32-bit OS
- HKEY_CURRENT_USER\Software\JomiTech\TwineCompiler
And finally, there'll be a string value under this key HKEY_CURRENT_USER\Software\Embarcadero\BDS\9.0\Known IDE Packages\CBuilder\, that references the TwineCompile package - delete the string value.
Post
by TKrauss » Mon Mar 05, 2012 12:53 pm
Thank you but this didn't change anything...
Same crash log as administrator!
What can I do now?
I already tried to reinstall CBuilder XE2 too...
