XE2 Update 4 - mtbcc32 exitted with code 1
TKrauss
Post by TKrauss »
After installing XE2 Update 4 on my Windows 7 x86 machine as standard user I get following error on every package:
[C++ Error] TCTargetsXE2.targets(446, 5): MSB6006 "mtbcc32" wurde mit Code 1 beendet.
  <Target Name="TCPerformLink" DependsOnTargets="_ResolveOutput;_CheckLinkDependencies">
    <TCLink
        Condition="'$(TLibLink)'!='true' And ('@(OutputOutOfDate)'!='' Or '$(ForceLink)'=='true')"
        ProjectFileName="$(MSBuildProjectFullPath)"
After clicking it shows the <TCLink line...
What is going wrong there?
Re: XE2 Update 4 - mtbcc32 exitted with code 1
"mtbcc32 exited with code 1" means that mtbcc32.exe (the TwineCompile C++ compiler executable) failed. Do you get any other errors in the console log?
TKrauss
Post by TKrauss »
If I try to compile with jtmake there is following output:
Target _PasDepCheck:
d:\WPS3\Entwicklungsumgebung\Source\wps3.cbproj wird übersprungen
C:\Program Files\JomiTech\TwineCompile\mtbcc32.exe -ide2012 -dep -priority
JomiTech TwineCompile 3.3 - Copyright JomiTech 2011. All Rights Reserved.
Compiling 355 files...
Starting executors...
Couldn't compile files. Message: Timeout waiting for executors to start.
With admin rights I get madexcept log. I tried to attach, but txt and log are not allowed extensions?!?
So I zipped the log file...
madexcept.zip
(4.68 KiB) Downloaded 4432 times
Are there any mtbcc32CompileExecutor.exe processes running? If there are, kill them, then try again.
Regarding the upload, we only allow zip files to be uploaded.
TKrauss
Post by TKrauss »
I tried again, but they are crashing with the same call stack in madExcept...
If you run with administrator rights, does it succeed?
TKrauss
Post by TKrauss »
The madexcept logs are under admin rights.
Under normal user rights there is no output in console...
TKrauss
Post by TKrauss »
I now reinstalled Update 3 because I had other problems too..
But there I can't compile too. Same error same logs!
Something is completely wrong in my system. How can I completly remove TwineCompile? Which systemfiles and regkeys do I have to delete manually?
Run the TwineCompile un-installer (via Add/Remove programs in Control Panel). It will remove all the TwineCompile files and registry settings.
You can then delete the following items:
- The TwineCompile Program Files directory (usually C:\Program Files (x86)\JomiTech\TwineCompile)
- The TwineCompile Users directory (C:\Users\<User Name>\AppData\Local\TwineCompile)
- HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\JomiTech\TwineCompile or
- HKEY_LOCAL_MACHINE\SOFTWARE\JomiTech\TwineCompile if you're on a 32-bit OS
- HKEY_CURRENT_USER\Software\JomiTech\TwineCompiler
And finally, there'll be a string value under this key HKEY_CURRENT_USER\Software\Embarcadero\BDS\9.0\Known IDE Packages\CBuilder\, that references the TwineCompile package - delete the string value.
TKrauss
Post by TKrauss »
Thank you but this didn't change anything...
Same crash log as administrator!
What can I do now?
I already tried to reinstall CBuilder XE2 too...
