The "DWARFVersion" parameter is not supported
kevin.moloney
Re: The "DWARFVersion" parameter is not supported
Post by kevin.moloney »
5.3.0
Can you confirm that the registry on the build machine has the HKEY_LOCAL_MACHINE\Software\Embarcadero\BDS\20.0\RootDir entry set to the location where C++Builder is installed?
kevin.moloney
No it is not. All I have is HKEY_LOCAL_MACHINE\Software\Embarcadero\InterBase\Servers\
Sorry, I forgot - look at the WOW6432Node - so HKEY_LOCAL_MACHINE\Software\WOW6432Node\Embarcadero\BDS\20.0\RootDir
kevin.moloney
Screenshot attached
(7.68 KiB) Not downloaded yet
Interesting - and weird. 5.3 added special logic to solve this issue with the assemblies not being loaded correctly. Is there any chance you can use jtmake instead of calling MSBuild yourself?
