The "DWARFVersion" parameter is not supported
Geocentrix
Post by Geocentrix »
I have just updated my version of Twine Compile to v5.0.0.158 and have hit a problem compiling with the CLANG compiler included with C++Builder 10.3.2.
Twine Compile works just fine with the Borland Classic compiler (BCC32).
But with CLANG, I get the error messages:
[MSBuild Error] TCTargets103.targets: MSB4064 The "DWARFVersion" parameter is not supported by the "TCQueueFileClang" task. Verify the parameter exists on the task, and it is a settable public instance property.
[MSBuild Error] TCTargets103.targets(567, 5): MSB4063 The "TCQueueFileClang" task could not be initialized with its input parameters.
Has anyone else had this problem and know a workaround?
Thanks in advance for any help.
Andrew
Re: The "DWARFVersion" parameter is not supported
DWARFVersion was a new property in 10.3 Update 3. If you're not using Update 3, you have to remove that property from the build targets file.
I have attached a copy to this reply. Extract into the TwineCompile Program Files directory.
TCTargets103.zip
(7.11 KiB) Downloaded 3578 times
kevin.moloney
Post by kevin.moloney »
We are seeing this exact issue too. Extracting that file into path does not fix issue either. We get
[MSBuild Error] TCTargets103.targets: MSB4064 The "StackAlign" parameter is not supported by the "TCQueueFileClang" task. Verify the parameter exists on the task, and it is a settable public instance property.
What is the exact version of C++Builder that you're using?
kevin.moloney
We are using `10.3.2`
Can you upgrade to 10.3 Update 3? That would resolve the issue.
kevin.moloney
Unfortunately not, company is out of subscription at the moment so cannot upgrade. Is there no alternative solution. Documentation outlines it would work for this version.
"TwineCompile 5.x supports C++Builder 10.2 through to C++Builder 10.4.1"
TwineCompile always only supports the latest update for any version.
To fix this issue, open that targets file in Notepad and remove the references to StackAlign, and save the file.
kevin.moloney
Thanks for that working through the ide now :)
However when running though our pipeline on build server after making relevant change to enable for msbuild we are seeing this error.
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets103.targets(436,5): error MSB4062: The "TCQueueFileClang" task could not be loaded from the assembly C:\Program Files (x86)\JomiTech\TwineCompile\JTBuildInterface103.dll. Could not load file or assembly 'Borland.Build.Tasks.Cpp, Version=26.0.0.0, Culture=neutral, PublicKeyToken=91d62ebb5b0d1b1b' or one of its dependencies. The system cannot find the file specified. Confirm that the <UsingTask> declaration is correct, that the assembly and all its dependencies are available, and that the task contains a public class that implements Microsoft.Build.Framework.ITask
What version of TwineCompile are you using?
