Something seems to be wrong with the TwinCompile 5.5.1 windows content update ( Builder 11.3 )
Often you will see unfinished statuses in "Compile status" after compilation. Console outputs are ok.
Similarly, "Compile Message" - often does not refresh the content. Only activating the window by clicking solves the problem and displays the messages.
Re: Something seems to be wrong with the TwinCompile 5.5.1 windows content update ( Builder 11.3 )
Please download the following file and extract into the TwineCompile Program Files directory. It should resolve this issue.
https://jomitech.com/downloads/TwineCom ... ore110.zip
The correction included in the patch is working. Thank you.
Unfortunately. The correction looked good, but when a compile error occurs, the "Compile Message" window still does not refresh itself
. It has to be clicked on.
