XE2 Update 4 - mtbcc32 exitted with code 1
Re: XE2 Update 4 - mtbcc32 exitted with code 1
Create a DWORD value called Logging, set to 1, in HKEY_CURRENT_USER\Software\JomiTech\TwineCompiler. Kill all the executors and try again. When it crashes, please zip up and send the log files from C:\Users\<User Name>\AppData\Local\TwineCompile to support at jomitech dot com.
I uploaded it here and sent you as mail...
The log is very small and after third complete reinstall of CBuilder the IDE crashes completly if I try to compile with TC!
Disabling TC helps but the amount of time for compilation with standard compiler is too big!
- TwineCompilerPlugin2012.zip
- (658 Bytes) Downloaded 1488 times
