Missing TwineCompile after Installation of April Patch for RAD Studio 12.3
After installing the April patch for RAD Studio 12.3, the previously installed TwineCompile is no longer displayed in the IDE's main menu bar, even after uninstalling/reinstalling.
Re: Missing TwineCompile after Installation of April Patch for RAD Studio 12.3
I can't reproduce this issue. TwineCompile is still showing up after that patch is installed. Make sure that the TwineCompile plugin is not listed in the Disabled IDE Packages section in the registry for RAD Studio, under this key:
HKEY_CURRENT_USER\SOFTWARE\Embarcadero\BDS\23.0
Hello - I can use TwineCompile again.
The problem arose when I tried to install the RAD Studio 12.3 April patch from the IDE. It doesn't work for me - I have no idea why. I installed the patch manually (downloaded via the embarcadero portal), and then TwineCompile works again.
I suspect that installing the patch from the IDE causes problems on certain installations.
I think this case can be left out of this forum; it's more of a RAD Studio issue.
