jtmake fails to determine project group version
Kerem
Post by Kerem »
When I try to run jtmake on a C++Builder project group, it reports "Failed to determine project version from ..."
I'm using RAD Studio Alexandria 11.3. I replaced jtmake.exe with the version provided in this post:
viewtopic.php?f=8&t=3282&p=7867&hilit=jtmake#p7867
Am I missing something?
Re: jtmake fails to determine project group version
I would suggest using the -ide110 parameter on the command-line to force the correct version. It sounds like the version # in the project file isn't explicit enough for jtmake to be able to automatically determine the correct version.
Kerem
Post by Kerem »
That was the solution, thank you very much. I tried it with 113 before.
