Auto incremental build number
nightman
Post by nightman »
For some reason, running with twincompiler "auto incremental biuld number" does not work correctly. It doesn't increment the number at all, or does so occasionally.
[Builder 11.2] Project->Options->Version info
Is it possible to correct this?
Re: Auto incremental build number
This also happens if you manually increase the build number. The change is not always applied when I build with TwineCompile.
nightman
Post by nightman »
In my case, manually changing the build number always works. Automatic numbering for projects where the result is *.exe never works. For projects where the result is *.dll increasing the number works with 90% efficiency when I manually add an empty "ProjectName.bpf" file to the project root.
Surprise.
