Precompiled Headers aren't rebuild on change (BCC32c)
I have an Issue that if I'm changing a header file wich is part of the precompiled header, I have to rebuild the package.
A normal build is not sufficient and there is an error thrown (mtbcc exited witch code 1).
Could you do anything, that a compile run when header file is changed leads automatically in a build of that project?
Best regards,
Thorsten
Re: Precompiled Headers aren't rebuild on change (BCC32c)
Unfortunately, this is an issue with the pre-compiled header not offering a dependency check. Not sure if the dependency information is even available in the compiled header. Do you have the same issue when you don't use TwineCompile?
No but there the PCH ist always built, even when there are no changes...
