Compiling C++Package classic compiler Error with TC
Remco
Post by Remco »
These errors only occur when using Twine Compile. When using bcc32 without TC, everything is OK.
version 11.0 CPPB
[C++ Error] iosfwd(385, 25): E2238 Multiple declaration for 'char_traits<wchar_t>::int_type'
[C++ Error] iosfwd(136, 25): E2344 Earlier declaration of 'char_traits<wchar_t>::int_type'
[C++ Error] iosfwd(391, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::assign(wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(141, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::assign(wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(396, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::eq(const wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(146, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::eq(const wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(401, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::lt(const wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(151, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::lt(const wchar_t &,const wchar_t &)'
[C++ Error] iosfwd(407, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::compare(const wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(156, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::compare(const wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(414, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::length(const wchar_t *)'
[C++ Error] iosfwd(167, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::length(const wchar_t *)'
[C++ Error] iosfwd(421, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::copy(wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(176, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::copy(wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(429, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::find(const wchar_t *,unsigned int,const wchar_t &)'
[C++ Error] iosfwd(187, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::find(const wchar_t *,unsigned int,const wchar_t &)'
[C++ Error] iosfwd(436, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::move(wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(197, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::move(wchar_t *,const wchar_t *,unsigned int)'
[C++ Error] iosfwd(443, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::assign(wchar_t *,unsigned int,wchar_t)'
[C++ Error] iosfwd(212, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::assign(wchar_t *,unsigned int,wchar_t)'
[C++ Error] iosfwd(454, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::to_int_type(const wchar_t &)'
[C++ Error] iosfwd(227, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::to_int_type(const wchar_t &)'
[C++ Error] iosfwd(465, 3): E2238 Multiple declaration for 'char_traits<wchar_t>::eof()'
[C++ Error] iosfwd(238, 3): E2344 Earlier declaration of 'char_traits<wchar_t>::eof()'
[C++ Error] iosfwd(486, 3): E2238 Multiple declaration for 'char_traits<char>::assign(char &,const char &)'
[C++ Error] iosfwd(141, 3): E2344 Earlier declaration of 'char_traits<char>::assign(char &,const char &)'
[C++ Error] iosfwd(491, 3): E2238 Multiple declaration for 'char_traits<char>::eq(const char &,const char &)'
[C++ Error] iosfwd(146, 3): E2344 Earlier declaration of 'char_traits<char>::eq(const char &,const char &)'
[C++ Error] iosfwd(496, 3): E2238 Multiple declaration for 'char_traits<char>::lt(const char &,const char &)'
[C++ Error] iosfwd(151, 3): E2344 Earlier declaration of 'char_traits<char>::lt(const char &,const char &)'
[C++ Error] iosfwd(502, 3): E2238 Multiple declaration for 'char_traits<char>::compare(const char *,const char *,unsigned int)'
[C++ Error] iosfwd(156, 3): E2344 Earlier declaration of 'char_traits<char>::compare(const char *,const char *,unsigned int)'
[C++ Error] iosfwd(509, 3): E2238 Multiple declaration for 'char_traits<char>::length(const char *)'
[C++ Error] iosfwd(167, 3): E2344 Earlier declaration of 'char_traits<char>::length(const char *)'
[C++ Error] iosfwd(516, 3): E2238 Multiple declaration for 'char_traits<char>::copy(char *,const char *,unsigned int)'
[C++ Error] iosfwd(176, 3): E2344 Earlier declaration of 'char_traits<char>::copy(char *,const char *,unsigned int)'
[C++ Error] iosfwd(524, 3): E2238 Multiple declaration for 'char_traits<char>::find(const char *,unsigned int,const char &)'
[C++ Error] iosfwd(187, 3): E2344 Earlier declaration of 'char_traits<char>::find(const char *,unsigned int,const char &)'
[C++ Error] iosfwd(531, 3): E2238 Multiple declaration for 'char_traits<char>::move(char *,const char *,unsigned int)'
[C++ Error] iosfwd(197, 3): E2344 Earlier declaration of 'char_traits<char>::move(char *,const char *,unsigned int)'
[C++ Error] iosfwd(538, 3): E2238 Multiple declaration for 'char_traits<char>::assign(char *,unsigned int,char)'
[C++ Error] iosfwd(212, 3): E2344 Earlier declaration of 'char_traits<char>::assign(char *,unsigned int,char)'
[C++ Error] iosfwd(549, 3): E2238 Multiple declaration for 'char_traits<char>::to_int_type(const char &)'
[C++ Error] iosfwd(227, 3): E2344 Earlier declaration of 'char_traits<char>::to_int_type(const char &)'
[C++ Error] iosfwd(560, 3): E2238 Multiple declaration for 'char_traits<char>::eof()'
[C++ Error] iosfwd(238, 3): E2344 Earlier declaration of 'char_traits<char>::eof()'
[C++ Error] xutility(346, 26): E2406 Dependent type qualifier 'bool' is not a class or struct type
[C++ Error] xutility(347, 26): E2406 Dependent type qualifier 'bool' is not a class or struct type
[C++ Error] xutility(348, 26): E2406 Dependent type qualifier 'bool' is not a class or struct type
[C++ Error] xutility(348, 26): E2228 Too many error or warning messages
Re: Compiling C++Package classic compiler Error with TC
This is very weird. Can you try to isolate the cause and create a test case?
Remco
Post by Remco »
I'm sending a test project. Win32 build with bcc32 without TC is OK. With TC it gives these errors: see atachment / ERROR folder.
twin.zip
(71.9 KiB) Downloaded 1601 times
Thank you for sending the test project. Unfortunately, it compiles with no issues for me. Are there are special steps you take that could be triggering this issue?
Remco
Post by Remco »
Hi Jon.
Unfortunately, there are no special steps. I have already detected this problem with the previous version (RAD 10.4. + TC5.2). Without TC, clang32 compiles without errors. I dont know what to do next.
Remco
Post by Remco »
Conclusion: some projects cannot be compiled in combination with bcc32c+TC or bcc32+TC. Compiling the same projects without TC is no problem. bcc64+TC does not generate this problem.
