TwineCompile loses breakpoints in Tokyo 10.2.3 in 32 bits compilation
asoler
Post by asoler »
We have just acquired TwineCompile and are using it at Embarcadero Tokyo 10.2.3. In 64 bits the compiler using TwineCompile allows us to debug. The 32 bit classic compiler, however, compiles and links but then the break points do not appear. Is this a known problem? Is there a solution? Right now what we do is disable TwineCompile and link the exe again but this is very tedious and slow.
Thank you in advance.
Re: TwineCompile loses breakpoints in Tokyo 10.2.3 in 32 bits compilation
Are you using TwineCompile v4.5 or v5.0?
asoler
Post by asoler »
I'm using version 5.0.0.133
