Installer 5
lukasb
Installer 5
Post by lukasb »
The installer of the version 5. seems to be corrupted - it doesnt lists available IDE`s to install and giving the user name and license key results in invalid user name or license key message.
Is there a way to install a registered version of 4.5 if we have buyed 5 - there wasn`t any options for buying 4.5.
We use TwineCompile in c++ builder xe5.
And futher tokyo.
Re: Installer 5
TwineCompile 5 only supports 10.2 Tokyo and 10.3 Rio.
If you want to use TwineCompile with an older IDE version (C++Builder 5 through to C++Builder 10.1 Berlin), you have to use TwineCompile 4.5. We will make this older version available to anyone who has a license to TwineCompile 5 on request.
Re: Installer 5
I installed both versions.
TC4.5 for XE2 and TC5 for 10.3, but now compilation fails in XE2.
I think this happens because there is no license key in Registry for TC4.5 anymore...
How do I work with both at same time?
Re: Installer 5
Did you install v5 on top of v4.5? They can share a license key.
Re: Installer 5
Yes I had TC4.5 installed and newly installed TC5.
If I try to use TC4.5 now I get the error
Exception thrown while building. (Object reference not set to an instance of an object)
Re: Installer 5
Re-install TwineCompile 4.5
