Rad Studio 10 Seattle
MStepanov
Post by MStepanov »
Hi, I have two errors:
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets10Seattle.targets : error MSB4064: The "UseClang" parameter is not supported by the "TCCompileFileList" task. Verify the parameter exists on the task, and it is a settable public instance property.
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets10Seattle.targets(717,5): error MSB4063: The "TCCompileFileList" task could not be initialized with its input parameters.
Re: Rad Studio 10 Seattle
Can you try re-downloading and re-installing TwineCompile? This error is usually caused by an older TwineCompile DLL file.
MStepanov
Post by MStepanov »
jomitech wrote:Can you try re-downloading and re-installing TwineCompile? This error is usually caused by an older TwineCompile DLL file.
I've just uninstalled and removed all files from JomiTech\TwineCompile\, reinstalled 4.4.0.82 version it didn't help. The same problem.
What version of RAD Studio 10 Seattle are you using?
MStepanov
Post by MStepanov »
Embarcadero® C++Builder 10 Seattle Version 23.0.21418.4207
What other versions of RAD Studio do you have installed on the same machine?
