Rad Studio 10 Seattle
Posted: Fri Sep 11, 2015 3:02 am
Hi there,
The new Rad Studio 10 is released with 32bit CLANG.
ETA for the new TwineComile?
Will it be 4.3 or 5.0 (and need to rebuy)?
Re: Rad Studio 10 Seattle
Posted: Mon Sep 28, 2015 8:50 am
We're looking into the possibility of releasing a TwineCompile version for C++Builder 10. Unfortunately we do not have any dates at this time.
Posted: Tue Oct 13, 2015 1:48 am
by Promentum
Do you have an update on Twine Compiler for C++ Builder 10?
I have bought 4 copies and it is soooo slow to build I can't bear to use them or roll them out to the team!
Posted: Tue Oct 13, 2015 4:50 am
by Promentum
One extra point, C++ 10 Seattle also permits the use of the 'Classic Borland compiler' so it should be a failry trivial job to chnage Twine compiler to work under 10 with the 'Classic' compiler, surely this would be the same environment as XE8?
Thanks in advance, Max
Posted: Tue Oct 20, 2015 8:44 am
We're working on the new version with Seattle support. Should be available in a few weeks.
Posted: Mon Oct 26, 2015 10:48 am
by Promentum
Thanks!
Twine Compiler is such a great product we really miss it.
Posted: Thu Oct 29, 2015 4:06 am
I installed the new version on my Windows 10 and got an error:
At compilation the IDE crashes because a library isn't registered!
Which library?
Posted: Thu Oct 29, 2015 3:57 pm
Can you provide the exact error that you receive? Is it just an error in the console output?
Posted: Fri Oct 30, 2015 1:54 am
The error in console when using jtmake is that there is an exception: a library isn't registered!
The IDE crashes without an exception when trying to compile a project.
Posted: Fri Oct 30, 2015 8:51 am
Please try the following steps:
1. Copy JTBuildInterface10Seattle.dll from the TwineCompile Program Files directory into the IDE bin directory
2. Open a command prompt with administrative rights, cd to the IDE bin directory and run:
C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm JTBuildInterface10Seattle.dll /tlb:JTBuildInterface10Seattle.tlb
3. Delete JTBuildInterface10Seattle.dll from the IDE bin directory.
4. Open an Explorer window in C:\Windows\Assembly and drag JTBuildInterface10Seattle.dll from the TwineCompile Program Files directory into it.
5. Restart the IDE/jtmake and try again.
