Rad Studio 10 Seattle
Hi there,
The new Rad Studio 10 is released with 32bit CLANG.
ETA for the new TwineComile?
Will it be 4.3 or 5.0 (and need to rebuy)?
Re: Rad Studio 10 Seattle
We're looking into the possibility of releasing a TwineCompile version for C++Builder 10. Unfortunately we do not have any dates at this time.
Promentum
Post by Promentum »
Do you have an update on Twine Compiler for C++ Builder 10?
I have bought 4 copies and it is soooo slow to build I can't bear to use them or roll them out to the team!
Promentum
Post by Promentum »
One extra point, C++ 10 Seattle also permits the use of the 'Classic Borland compiler' so it should be a failry trivial job to chnage Twine compiler to work under 10 with the 'Classic' compiler, surely this would be the same environment as XE8?
Thanks in advance, Max
We're working on the new version with Seattle support. Should be available in a few weeks.
Promentum
Post by Promentum »
Thanks!
Twine Compiler is such a great product we really miss it.
I installed the new version on my Windows 10 and got an error:
At compilation the IDE crashes because a library isn't registered!
Which library?
Can you provide the exact error that you receive? Is it just an error in the console output?
The error in console when using jtmake is that there is an exception: a library isn't registered!
The IDE crashes without an exception when trying to compile a project.
Please try the following steps:
1. Copy JTBuildInterface10Seattle.dll from the TwineCompile Program Files directory into the IDE bin directory
2. Open a command prompt with administrative rights, cd to the IDE bin directory and run:
C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm JTBuildInterface10Seattle.dll /tlb:JTBuildInterface10Seattle.tlb
3. Delete JTBuildInterface10Seattle.dll from the IDE bin directory.
4. Open an Explorer window in C:\Windows\Assembly and drag JTBuildInterface10Seattle.dll from the TwineCompile Program Files directory into it.
5. Restart the IDE/jtmake and try again.
