Static libraries
Posted: Wed Jan 25, 2012 3:46 am
I cannot build static libraries with XE2 and latest TC...
There are errors with package version (with dynamic libraries these errors don't appear) and wrong TLIB parameters!
What can I do?
TLIB Error:
[MSBuild Error] TCTargetsXE2.targets: MSB4064 The "LibraryFile" parameter is not supported by the "TLIB" task. Verify the parameter exists on the task, and it is a settable public instance property.
[MSBuild Error] TCTargetsXE2.targets: MSB4063 The "TLIB" task could not be initialized with its input parameters.
Re: Static libraries
Posted: Thu Jan 26, 2012 8:22 am
What version of XE2 are you using?
Posted: Thu Jan 26, 2012 11:41 am
The latest one: Update 3
Posted: Fri Jan 27, 2012 8:29 am
Extract the attached file into the BDS\bin folder. It should fix this issue.
Posted: Thu Feb 02, 2012 12:38 pm
Thank you! Works like a charm...
Posted: Thu Apr 19, 2012 9:13 am
by WindSolutions
Exact same problem here but the above fix doesn't work. RAD Studio XE2 update 4.
Any clue?
Posted: Mon Apr 23, 2012 11:06 am
by WindSolutions
I dug a bit further and found the cause of the bug. I checked the Messages > Output memo to find the following:
c:\program files (x86)\embarcadero\rad studio\9.0\bin\bcc32.exe -D_DEBUG -D_RTLDLL;USEPACKAGES -nWin32\Debug -I"C:\Program Files (x86)\Embarcadero\RAD Studio\9.0\include\boost_1_39\boost\tr1\tr1";"C:\Program Files (x86)\Embarcadero\RAD Studio\9.0\include\boost_1_39";"c:\program files (x86)\embarcadero\rad studio\9.0\include";"c:\program files (x86)\embarcadero\rad studio\9.0\include\dinkumware";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\crtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\sdk";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\rtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\vcl";"C:\Program Files (x86)\FastReports\LibD16";"c:\program files (x86)\embarcadero\rad studio\9.0\RaveReports\Lib";"C:\Program Files (x86)\Raize\CS5\Lib\RS-XE2\Win32";"C:\VCLExts\TJD\BuilderXe2";"C:\Users\Public\Documents\RAD Studio\9.0\hpp" -y -Q -k -6 -r- -c -tW -C8 -oWin32\Debug\sqlite3.obj -w-par -Od -v -vi- -H=Win32\Debug\sqlite_XE2.pch -H sqlite3.c
The following folder did not exist and was causing the error: C:\VCLExts\TJD\BuilderXe2. I deleted the folder from Tools > Options > C++ Options > Paths and Directories, restarted the IDE and bug was fixed. Maybe it is possible to check the various paths and not add the invalid ones?
Posted: Wed Apr 25, 2012 8:44 am
Glad you figured it out. The folder handling is part of the Embarcadero MSBuild code, but I'll see if I can make TC check the paths before they're passed to the compiler/linker/librarian.
