I cannot build static libraries with XE2 and latest TC...
There are errors with package version (with dynamic libraries these errors don't appear) and wrong TLIB parameters!
What can I do?
TLIB Error:
[MSBuild Error] TCTargetsXE2.targets: MSB4064 The "LibraryFile" parameter is not supported by the "TLIB" task. Verify the parameter exists on the task, and it is a settable public instance property.
[MSBuild Error] TCTargetsXE2.targets: MSB4063 The "TLIB" task could not be initialized with its input parameters.
Static libraries
Re: Static libraries
The latest one: Update 3
Extract the attached file into the BDS\bin folder. It should fix this issue.
- Attachments
- TCTargetsXE2.zip
- (4.93 KiB) Downloaded 3793 times
Thank you! Works like a charm...
WindSolutions
Exact same problem here but the above fix doesn't work. RAD Studio XE2 update 4.
Any clue?
Any clue?
WindSolutions
I dug a bit further and found the cause of the bug. I checked the Messages > Output memo to find the following:
c:\program files (x86)\embarcadero\rad studio\9.0\bin\bcc32.exe -D_DEBUG -D_RTLDLL;USEPACKAGES -nWin32\Debug -I"C:\Program Files (x86)\Embarcadero\RAD Studio\9.0\include\boost_1_39\boost\tr1\tr1";"C:\Program Files (x86)\Embarcadero\RAD Studio\9.0\include\boost_1_39";"c:\program files (x86)\embarcadero\rad studio\9.0\include";"c:\program files (x86)\embarcadero\rad studio\9.0\include\dinkumware";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\crtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\sdk";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\rtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\vcl";"C:\Program Files (x86)\FastReports\LibD16";"c:\program files (x86)\embarcadero\rad studio\9.0\RaveReports\Lib";"C:\Program Files (x86)\Raize\CS5\Lib\RS-XE2\Win32";"C:\VCLExts\TJD\BuilderXe2";"C:\Users\Public\Documents\RAD Studio\9.0\hpp" -y -Q -k -6 -r- -c -tW -C8 -oWin32\Debug\sqlite3.obj -w-par -Od -v -vi- -H=Win32\Debug\sqlite_XE2.pch -H sqlite3.c
The following folder did not exist and was causing the error: C:\VCLExts\TJD\BuilderXe2. I deleted the folder from Tools > Options > C++ Options > Paths and Directories, restarted the IDE and bug was fixed. Maybe it is possible to check the various paths and not add the invalid ones?
Glad you figured it out. The folder handling is part of the Embarcadero MSBuild code, but I'll see if I can make TC check the paths before they're passed to the compiler/linker/librarian.
