SORTA set to 0ms does not compile
gbrandt
Post by gbrandt »
TwineCompile 3.2.0.213
When SORTA compile is set to activate with 0ms, the compile never occurs.
Works properly when set to 100ms.
Gregor
Re: SORTA set to 0ms does not compile
Thanks for reporting this. After investigation, it appears that the VCL TTimer control will not enable with an Interval of 0. So an interval of 0 is not possible.
gbrandt
Post by gbrandt »
Can this be changed to 1?
Gregor
The windows timer has a minimum resolution of 10ms, so in the next update to TwineCompile, we'll remove 0ms and replace it with 10ms.
