We want to use TwineCompile on a server. If the mtbcc32* threads are already loaded, we often get error "Fermeture de "mtbcc32" avec le code 3".
If we kill the process mtbcc32 *, the compilation works again.
The problem exists on version 4.5 and on trial version 5.0.
Can you help us to avoid this problem ?
Can you provide the full version # of TwineCompile that you have installed? There were some issues with the handling of simultaneous compiles that we resolved in a fairly recent build of v5.
Please enable logging and then send the log files to support@jomitech.com. To enable the logs, create a DWORD registry value called Logging, set to 1, in the HKEY_CURRENT_USER\Software\JomiTech\TwineCompiler key.
The logs will be written to C:\Users\<User Name>\AppData\Local\TwineCompile
