I followed your instructions and added the "Import" line to my project file. Here are my Imports from the project file:
Here is my command Line:<Import Project="$(BDS)\Bin\CodeGear.Cpp.Targets" Condition="Exists('$(BDS)\Bin\CodeGear.Cpp.Targets')"/>
<Import Project="C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets10Seattle.targets" />
<Import Project="$(APPDATA)\Embarcadero\$(BDSAPPDATABASEDIR)\$(PRODUCTVERSION)\UserTools.proj" Condition="Exists('$(APPDATA)\Embarcadero\$(BDSAPPDATABASEDIR)\$(PRODUCTVERSION)\UserTools.proj')"/>
<Import Project="$(MSBuildProjectName).deployproj" Condition="Exists('$(MSBuildProjectName).deployproj')"/>
Here is the build error:call "C:\Program Files (x86)\Embarcadero\Studio\17.0\bin\rsvars.bat"
C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe Poles.cbproj /t:build
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets10Seattle.targets(110,5): error MSB4062: The "TCQueueFile" task could not be loaded from the assembly C:\Program Files (x86)\JomiTech\TwineCompile\JTBuildInterface10Seattle.dll. Could not load file or assembly 'Borland.Build.Tasks.Cpp, Version=23.0.0.0, Culture=neutral, PublicKeyToken=91d62ebb5b0d1b1b' or one of its dependencies. The system cannot find the file specified. Confirm that the <UsingTask> declaration is correct, that the assembly and all its dependencies are available, and that the task contains a public class that implements Microsoft.Build.Framework.ITask. [C:\WS\Code\PolesProjects\Poles\Poles.cbproj]
Done Building Project "C:\WS\Semaan - Engineering - 2011\Branches\Engineering - 2017-01-11 - US_PolesAndTowers_Branch\Code\PolesProjects\Poles\Poles.cbproj" (build target(s)) -- FAILED.
Build FAILED.
"C:\WS\Code\PolesProjects\Poles\Poles.cbproj" (build target) (1) ->
(TCBuildFileListBcc target) ->
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets10Seattle.targets(110,5): error MSB4062: The "TCQueueFile" task could not be loaded from the assembly C:\Program Files (x86)\JomiTech\TwineCompile\JTBuildInterface10Seattle.dll. Could not load file or assembly 'Borland.Build.Tasks.Cpp, Version=23.0.0.0, Culture=neutral, PublicKeyToken=91d62ebb5b0d1b1b' or one of its dependencies. The system cannot find the file specified. Confirm that the <UsingTask> declaration is correct, that the assembly and all its dependencies are available, and that the task contains a public class that implements Microsoft.Build.Framework.ITask. [C:\WS\Semaan - Engineering - 2011\Branches\Engineering - 2017-01-11 - US_PolesAndTowers_Branch\Code\PolesProjects\Poles\Poles.cbproj]
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.54
"=============End Build==============="
