PA64
Posts: 9 Joined: Tue Apr 22, 2014 8:54 am
Post
by PA64 » Tue Apr 22, 2014 9:24 am
Dear Jomitech,
Will there soon be a new version of TwinCompile for XE6?
Are you planning to support parallel compilation of 64-bit C++ files with XE6?
(The 64bit compiler is much slower than the 32bit compiler!)
Best Regards.
Peter
Posts: 2185 Joined: Wed Oct 08, 2008 12:23 am
Post
by jomitech » Thu Apr 24, 2014 11:55 am
We are working on the XE6 version for the 32-bit compiler. The 64-bit one is still under consideration.
Since you mention that the 64-bit compiler is slower than the 32-bit one, can you provide the following:
32-bit compile time without TwineCompile
32-bit compile time with TwineCompile
64-bit compile time
PA64
Post
by PA64 » Wed Apr 30, 2014 6:15 am
Compile speeds of a converted runtime-package [BPL]:
00:14:11.6 XE6 64Bit Debug
00:01:42.1 XE6 32Bit Debug
00:00:39.23 CPPB2010 32Bit Debug
00:00:23.99 CPPB2010 32Bit Debug with TwineCompile
Post
by jomitech » Wed Apr 30, 2014 8:35 am
That is very interesting. It's significantly slower than the 32-bit compiler.
Post
by jomitech » Tue Jun 03, 2014 8:32 am
TwineCompile 4.0 has been released with full support for the 64-bit compilers from XE3 through to XE6.
TKrauss
Posts: 97 Joined: Thu Jul 21, 2011 8:22 am
Post
by TKrauss » Wed Jun 04, 2014 5:24 am
Good news!
But would it be possible to support XE6 in a version 3.7?
Until now and in near future we don't use the 64bit-compiler, so we have to buy the version 4 only for XE6 and not for the 64bit features!
Post
by jomitech » Wed Jun 04, 2014 8:54 pm
Unfortunately, we do not plan to add XE6 support into TwineCompile 3.
TKrauss
Post
by TKrauss » Mon Jun 30, 2014 1:29 am
I now have installed XE6 with TwineCompile 4, but when trying to compile a new package the ide crashes!
On command line with jtmake it is working.
Any idea?
Can I send logs to you?
TKrauss
Post
by TKrauss » Mon Jun 30, 2014 7:45 am
I uninstalled TC and reinstalled it and now it works!
Sorry!
