If I add a pas-file to a C++Builder-Project and try to compile with TwineCompile the window of compilation status disappears and there is no error output.
There I have to disable TwineCompile everytime a pas-file contains a compilation error!
What can I do? Is this the normal behaviour?
C++Builder DCC-Errors
Re: C++Builder DCC-Errors
No, that is not normal. I have several BCB projects that contain pas files and they work fine. This is XE2, right?
Yes that's right!
This happens under Windows XP or Windows 7 with XE2!
Currently we are using Update 4 HF1 but I think this error has nothing to do with this update...
Did you already had time to investigating?
Thank you! This fix works!
Edit:
Since I use the dll out of your fix you sent me by mail I can't remove projects out of the projectgroup anymore.
I attached the madExcept-log...
Edit:
- bugreport.zip
- (23.5 KiB) Downloaded 2621 times
Hi Jon,
Could you please resend me the latest fix?
