Couldn't compile files.
Yannick CDIP
Post by Yannick CDIP »
Hello,
I have problem when I want to compile my project with command lines :
Couldn't compile files. Message: Can't create cancellation pipe..
C:\Program Files\JomiTech\TwineCompile\TCTargets10.targets(130,5): error MSB6006: Fermeture de "bcc32" avec le code 1.
Who has an idea ?
Yannick
Re: Couldn't compile files.
What operating system are you using? Are you running the command-line with administrator rights (I'm not saying that it requires it, just trying to get as much information as possible)?
Yannick CDIP
Hello,
I use Windows Vista Professional and I have administrator right.
Yannick
I have attached an updated mtbcc32.exe trial version that reports the system error code when CreateNamedPipe fails.
mtbcc32.zip
(548.05 KiB) Downloaded 1670 times
Yannick CDIP
It's good, I once compiled the project under Builder C++ with Twine Compiles and now it works. Thank you very much
That's strange. I didn't change any other code in there since the 3.2 release.
