The new Twine is working well!
Is there an upgrade price from version 2?
Andy
Twine Compile 3 and ULINK
Re: Twine Compile 3 and ULINK
Yes, $69, or more than 50% off. To get it, just make sure you're logged into the JomiTech site, and the order process will give you the option to upgrade your licence.
Ummm... I tried that but got no offer of an upgrade or discount. I definitely have Twine 2 (user name RiBell)...
Andy
Andy
Did you click the "Buy Now for only $139!" link? You'll be taken to an order page where (if you're logged in), you can upgrade.
Yes - did that. Yes - was logged in. No - that order page does not appear, only the $139 order page appears...jomitech wrote:Did you click the "Buy Now for only $139!" link? You'll be taken to an order page where (if you're logged in), you can upgrade.
Andy
On the $139 order page, it should list 3 options:AndyBell wrote:Yes - did that. Yes - was logged in. No - that order page does not appear, only the $139 order page appears...
- Purchase a named user licence for $139.
- Purchase a site licence for $1390
- Upgrade an existing TwineCompile 2 licence for $69
Don't you see this?
Thanks! It's working now.
I'm also looking for a replacement linker for the iLink32, so I tried the ulinker, but I'm also getting the same error ([ulink Error] ilink32 has exited with code 3.).
Did you get ulink to work with the virtual file system? The only way I can get ulink to work is to disable the virtual file system
Does anyone know another replacement linker that supports the virtual file system? Because the iLink32 is starting to fail on a very regular base... (out of memory errors).
Thanks
Thanks
