Usage in docker
miskol
Usage in docker
Post by miskol »
I want to use TwineCompile in docker
I can install TwineCompile in RAD Studio with getIt as I have license for RAD Studio.
So how can I transfer license to my docker image?
Or can use it without license ?
I want to use it for CI/CD with gitlab/github/gitea
Re: Usage in docker
You can transfer the necessary files (jtmake.exe, mtbcc32.exe etc..) into your Docker image and use them without transferring any licenses. The license is linked to the IDE plugin, which I'm guessing you won't be using in the Docker image.
Let me know if that works for you, or feel free to provide additional context.
miskol
Re: Usage in docker
Post by miskol »
I installed TwineCompile
Start-Process -NoNewWindow -Wait -FilePath 'C:\TwineCompile582TrialSetup.exe' -ArgumentList '/VERYSILENT', '/SUPPRESSMSGBOXES', '/NORESTART'
But it show me it is 30 day trial and it is counting down.
As I installed TwineCompile into docker image as step in Dockerfile
Yes, I can install TwineCompile every time I start docker image so I will have fresh 30 day trial :D
It is supper fast.
Any suggestions ?
Are there any difference when I have trial vs it isn't trial?
Re: Usage in docker
I would recommend just building the files directly into your docker image instead of installing TwineCompile every time. You can get them from the TwineCompile Program Files directory that's created when installing off Get it.
There isn't really any overhead for using the trial, except for the trial warnings that are emitted during a compile, but installing each time will make your docker image start slower.
miskol
Re: Usage in docker
Post by miskol »
Can you plz extend your TwineCompile license that we can use TwineCompile for free in docker for build server?
Re: Usage in docker
The TwineCompile license does permit the use of TwineCompile in a build server. That's why I said you can just copy the files right over - it will work correctly.
miskol
Re: Usage in docker
Post by miskol »
Great thx
miskol
Re: Usage in docker
Post by miskol »
But when I install TwineCompile on Build server or into docker from
https://www.jomitech.com/trial.php?p=TwineCompile5
It will expire after 30days
So How can I install TwineComile on build server or docker?
Do I need to buy license for that ?
Re: Usage in docker
Install TwineCompile into the build server or Docker image, then copy the files into the installation folder from C:\Program Files (x86)\JomiTech\TwineCompile on your dev machine that has TwineCompile installed from GetIt. This will overwrite the trial files with the registered version that's in the IDE and allow you to use it on your build server or docker image.
