Install TwineCompile582TrialSetup.exe from command line
miskol
Post by miskol »
How to install TwineCompile582TrialSetup.exe from command line?
Are there any list of known parameters?
And how can I install it to specific folder?
Re: Install TwineCompile582TrialSetup.exe from command line
You can use the command
TwineCompile582TrialSetup.exe /?
to view the available command-line commands. Use
/DIR="C:\Test"
to set a default directory.
