Auto recognize ide from ProjectVersion
Posted: Mon Mar 20, 2023 11:44 am
Hi
I'm using jtmake to compile multiple versions of Embarcadero projects, such as RAD Studio XE4, Tokyo(10.2) and I recently started using RAD Studio version 11.2.
when I'm creating/changing a project using RAD Studio 11.2 it automatically changes the ProjectVersion to 19.5, but then when I run from the command-line the following command: jtmake "MyProject" I get an error:
Unknown project version "19.5".
if I manually edit the cbproj and change the ProjectVersion to 19.4 it works perfectly.
I know that the suggested solution is to explicitly specify the -ide flag while calling jtmake, but since I have multiple tools & procedures that use jtmake for different versions of the IDEs, it means that I'll have to change all of them to identify the correct -ide flag for each version.
Is there any way to make TwineCompile recognize projects with version 19.5 without having to add an extra flag?
I tried with TwineCompile from Get-It(version 5.4.2), and also with the latest trial version (version 5.5.1) and the issue persists.
Thanks in advance.
Thanks in advance.
