Issue with C++ Builder 11.2 when building from a project group
Posted: Mon Sep 19, 2022 4:39 am
If I build in C++Builder-IDE a project group (6 projects, with TC on), the 6 exes do not include the customized icons.
If I build only one project within this project group (with TC on), it builds the single, corresponding exe fine with the intended icon resource.
I verified this with switching off TwineCompile in the IDE and "Clean ALL", "Build All" from the project group...result: all exes build properly (ok, building took an eternity without TC).
Back, switching on TwineCompile, "Clean ALL", "Build All" from the project group...result: all exes do not have the expected icon (and exes are a bit shorter, about the size of the icon file).
Additionally I built the project group outside IDE with msbuild...result: all exes built properly with the expected icons in it.
So it seems to me, there is an issue with TwineCompile when building all projects of a project group in the IDE.
TC: 5.4.0.14 (latest found in https://my.embarcadero.com)
C++ Builder 11.2
Please fix this in TwineCompile, so that a release build over all projects in a project group in the IDE can be done at once (with use of TC).
Kind Regards
C++ Builder 11.2
Kind Regards
