Final Builder issues
Posted: Wed Apr 13, 2022 9:17 am
by AndyPhotosBell
Hi
I'm using Twine 5.4.0.14 with BCB 11.1. I installed Twine from Getit...
I imported the Twine Final Builder action into Final Builder and created a FB Twine action. However, the TwineCompile build options only offered C++ Builder 2007 as a Project version, which seems weird as the project is a BCB 11.1 one, which builds fine with Twine in the IDE. I don't have BCB 2007 installed on this PC, although I do have V2009.
In any case, I linked the Twine Action to my project but when I tried to build it failed with the message:
Project builder exception. (Library not registered)
Any clues for overcoming these issues would be appreciated...
Andy
Re: Final Builder issues
Posted: Fri Apr 15, 2022 6:23 pm
Which FB action did you add into FinalBuilder? TwineCompile ships with several actions, one for each version of FinalBuilder. You probably need to use the latest one (TwineCompileBuild8.fbap), which has 11.0 (the version you need to use)
Posted: Fri Jul 01, 2022 8:06 am
by AndyPhotosBell
Sorry for the very late follow up...
Yes, I imported TwineCompileBuild8.fbap into FinalBuilder.
Since then, I have uninstalled and reinstalled Twine and upgraded to BCB 11.1. I still get exactly the same issues.
TwineCompileBuild8.fbap is dated 17/1/2022
Andy
Posted: Mon Jul 04, 2022 11:13 am
I think I know what the issue is. Try the attached FinalBuilder action.
Posted: Mon Jul 11, 2022 4:59 am
by AndyPhotosBell
Hi Jonathan
Unfortunately, this didn't make a difference. It still only offered BCB 2007 as a compiler option.
I have worked around by making a batch file calling jtmake.exe and calling that from FinalBuilder. It works fine and I'm guessing does exactly what the plugin does...
Andy
