Linker error - unresolved external since TC 5.3
Posted: Thu Mar 17, 2022 3:31 pm
by QimiaoLu
I have the linker error ([Linker Error] Error: Unresolved external 'xxxx' referenced from xxxx) since TC5.3. TC5.4 produced the same errors. If TC is disabled, all packages can be compiled successfully without such linker errors. Any help? Thanks.
Qimiao
Re: Linker error - unresolved external since TC 5.3
Posted: Thu Mar 17, 2022 6:19 pm
Try turning off Parallel Project building in the TwineCompile options and see if that resolves this issue.
Posted: Tue Mar 29, 2022 12:38 pm
by QimiaoLu
Turning off Parallel Project Building does not solve the issue. I did more investigation on the issue. My package B depends on package A. Package B uses the exported functions declared in Package A.
When I enable TC, I have no error in building Package A but get the link unresolved external error in buiding Package B.
When I disable TC, I can build both packages without such link error.
Firstly, I disable TC and rebuild Package A. Then I enable TC and build Package B successfuly without error.
The above-mentioned issue does not occur when I build the packages in WIN64 platform.
I am using TC 5.4 and RAD 11.1 now.
Posted: Tue Mar 29, 2022 5:22 pm
This sounds like a known issue with the IDE caching the package. TwineCompile does not have access to the IDE internals to force that cache to reset. We're trying to work with Embarcadero to get access to this.
