Cannot install into multiple IDEs with GetIt Package Manager
Posted: Fri Nov 05, 2021 3:00 pm
I have been using Twine with RAD Studio 10.4 since it was made available through GetIt Package Manager. I then installed it into RAD Studio 11.0 via GetIt. Afterward, the RS10.4 installation did not work correctly. I uninstalled it from RS10.4 which corrupted the RS11.0 installation so badly that I was unable to uninstall from RS11.0 through GetIt. I had to remove the package using regedit in order to reinstall.
The reason for the problems is the installation directory used for both RS10.4 and RS11.0 is the same (C:\Program Files (x86)\JomiTech\TwineCompile). I assume this is fine for the standard installation of Twine (usable by all IDE versions) but it does not work for installations via GetIt. They are different versions of Twine and they interfere with the GetIt mechanism.
Currently, I am only able to use Twine to compile in one version of the IDE at a time. If I usually work in RS11.0 and know I'll be working in RS10.4 for a while then I will uninstall Twine from RS11.0 and install it in RS10.4. It would be fantastic if these installations could exist at the same time.
Thank you
Thank you
