Page 1 of 2
RLINK32 Error opening File "C:\...\*.dfm"
Posted: Fri Sep 11, 2020 12:37 pm
by Chris
Hello,
we have very often the Problem, that we get the above mentioned Error while Linking for Forms that are opened in the IDE. For each Form, that is opened, we have to go to the File and open the Designer. This hapens in every Project. We are using the Version of TwineCompile, which is available via GetIt with the Standard-Settings.
Is there a way to get rid of this error?
Thanks,
Chris
Re: RLINK32 Error opening File "C:\...\*.dfm"
Posted: Mon Sep 14, 2020 6:35 pm
This sounds like something is locking the dfm files in the IDE. Do you have any third-na extensions installed that interact with the form designer?
Posted: Mon Sep 14, 2020 11:27 pm
by Chris
No, the only things we have installed are TMS-Components (VCL UI Pack/WEB GMaps) and EUREKA-Log (which is in most programs not even enabled). Neither of them should lock the .dfms (afaik).
Posted: Tue Sep 15, 2020 6:17 pm
Can you copy the entire contents of the Console Output tab in the compile window and paste it here?
Posted: Tue Sep 15, 2020 11:36 pm
by Chris
Sure, here's it:
Making...
Der Buildvorgang wurde am 16.09.2020 06:33:26 gestartet.
__________________________________________________
Projekt C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\WolfDatenbankzugriff.cbproj (Make-Ziel(e)):
MakeObjs-Ziel:
    _PasDepCheck-Ziel:
        C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\WolfDatenbankzugriff.cbproj wird übersprungen
    TCInitFileList-Ziel:
        Die Datei C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\twfiles.@@@ wird gelöscht.
Compiling C++ files...
    TCCompile-Ziel:
        C:\Program Files (x86)\JomiTech\TwineCompile\mtbcc32.exe -ide104 -dep -priority0 -files="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\twfiles.@@@"
        JomiTech TwineCompile 5.2 - Copyright JomiTech 2020. All Rights Reserved.
        Compiling 1 files...
        Embarcadero C++ 7.50 f³r Win32 Copyright (c) 1993-2017 Embarcadero Technologies, Inc.
        C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\TDat\Kopf\TDatViewKopfGesamt.cpp
        TDatViewKopfGesamt.cpp: (0) 0 of 0
        TDatViewKopfGesamt.cpp: (0) 965888 of 965888
        TDatViewKopfGesamt.cpp: (0) 1388381 of 1388381
        Compiled 1 files in 1,75 secs.
Linking...
TCPerformLink-Ziel:
    Die Datei Bin\WolfDatenbankzugriff.lib wird gelöscht.
    c:\program files (x86)\embarcadero\studio\21.0\bin\tlib.exe /N Bin\WolfDatenbankzugriff.lib /a Build_Debug\TAuftragsdatenFuerProjektleiste.obj /a Build_Debug\TDatenbankzugriff.obj /a Build_Debug\TDatAdresse.obj /a Build_Debug\TDatAdresseBase.obj /a Build_Debug\TDatAdresseTyp.obj /a Build_Debug\TDatAdresseTypBase.obj /a Build_Debug\TDatAllgText.obj /a Build_Debug\TDatAllgTextBase.obj /a Build_Debug\TDatArtAllgtext.obj /a Build_Debug\TDatArtAllgtextBase.obj /a Build_Debug\TDatAnrede.obj /a Build_Debug\TDatAnredeBase.obj /a Build_Debug\TDatAnsprechperson.obj /a Build_Debug\TDatAnsprechpersonBase.obj /a Build_Debug\TDatViewArbeitszeit.obj /a Build_Debug\TDatViewArbeitszeitBase.obj /a Build_Debug\TDatArt.obj /a Build_Debug\TDatArtBase.obj /a Build_Debug\TDatKopfAenderung.obj /a Build_Debug\TDatKopfAenderungBase.obj /a Build_Debug\TDatAuftragschance.obj /a Build_Debug\TDatAuftragschanceBase.obj /a Build_Debug\TDatBestellungKopf.obj /a Build_Debug\TDatBestellungKopfBase.obj /a Build_Debug\TDatViewBestellung.obj /a Build_Debug\TDatViewBestellungBase.obj /a Build_Debug\TDatViewChecklistenPosition.obj /a Build_Debug\TDatViewChecklistenPositionBase.obj /a Build_Debug\TDatArtPositionOrdner.obj /a Build_Debug\TDatArtPositionOrdnerBase.obj /a Build_Debug\TDatDateiUebertragen.obj /a Build_Debug\TDatDateiUebertragenBase.obj /a Build_Debug\TDatThumbnail.obj /a Build_Debug\TDatThumbnailBase.obj /a Build_Debug\TDatViewDatei.obj /a Build_Debug\TDatViewDateiBase.obj /a Build_Debug\TDatFakturaDetailVerrechnet.obj /a Build_Debug\TDatFakturaDetailVerrechnetBase.obj /a Build_Debug\TDatKonzernEinstellung.obj /a Build_Debug\TDatKonzernEinstellungBase.obj /a Build_Debug\TDatViewFakturaUebersicht.obj /a Build_Debug\TDatViewFakturaUebersichtBase.obj /a Build_Debug\TDatZahlungseingang.obj /a Build_Debug\TDatZahlungseingangBase.obj /a Build_Debug\TDatFavoriten.obj /a Build_Debug\TDatFavoritenBase.obj /a Build_Debug\TDatKopfPositionFormular.obj /a Build_Debug\TDatKopfPositionFormularBase.obj /a Build_Debug\TDatWertFormular.obj /a Build_Debug\TDatWertFormularBase.obj /a Build_Debug\TDatHauptmenueProjekt.obj /a Build_Debug\TDatHauptmenueProjektBase.obj /a Build_Debug\TDatHerkunft.obj /a Build_Debug\TDatHerkunftBase.obj /a Build_Debug\TDatHistorie.obj /a Build_Debug\TDatHistorieBase.obj /a Build_Debug\TDatKalender.obj /a Build_Debug\TDatKalenderArt.obj /a Build_Debug\TDatKalenderArtBase.obj /a Build_Debug\TDatKalenderBase.obj /a Build_Debug\TDatKopfAnsprechperson.obj /a Build_Debug\TDatKopfAnsprechpersonBase.obj /a Build_Debug\TDatKopfFreigabe.obj /a Build_Debug\TDatKopfFreigabeBase.obj /a Build_Debug\TDatKopf.obj /a Build_Debug\TDatKopfBase.obj /a Build_Debug\TDatViewKopfFreigabe.obj /a Build_Debug\TDatViewKopfFreigabeBase.obj /a Build_Debug\TDatViewKopfGesamt.obj /a Build_Debug\TDatViewKopfGesamtBase.obj /a Build_Debug\TDatViewKopfGesamt_Duplikatssuche.obj /a Build_Debug\TDatViewKopfGesamt_DuplikatssucheBase.obj /a Build_Debug\TDatViewLand.obj /a Build_Debug\TDatViewLandBase.obj /a Build_Debug\TDatViewMontagelisten.obj /a Build_Debug\TDatViewMontagelistenBase.obj /a Build_Debug\TDatLogbuch_Datenbankzugriff.obj /a Build_Debug\TDatLogbuch_DatenbankzugriffBase.obj /a Build_Debug\TDatMandant.obj /a Build_Debug\TDatMandantBase.obj /a Build_Debug\TDatViewMitarbeiterAnwesend.obj /a Build_Debug\TDatViewMitarbeiterAnwesendBase.obj /a Build_Debug\TDatMitarbeiterEinstellung_Datenbankzugriff.obj /a Build_Debug\TDatMitarbeiterEinstellung_DatenbankzugriffBase.obj /a Build_Debug\TDatMitarbeiterEndgeraet.obj /a Build_Debug\TDatMitarbeiterEndgeraetBase.obj /a Build_Debug\TDatMitarbeiterGruppeLetzteNr.obj /a Build_Debug\TDatMitarbeiterGruppeLetzteNrBase.obj /a Build_Debug\TDatMitarbeiterGruppeMitglieder.obj /a Build_Debug\TDatMitarbeiterGruppeMitgliederBase.obj /a Build_Debug\TDatPE_MitarbeiterZuRecht.obj /a Build_Debug\TDatPE_MitarbeiterZuRechtBase.obj /a Build_Debug\TDatViewMitarbeiterRechte_Datenbankzugriff.obj /a Build_Debug\TDatViewMitarbeiterRechte_DatenbankzugriffBase.obj /a Build_Debug\TDatKontakteSuchen.obj /a Build_Debug\TDatKontakteSuchenBase.obj /a Build_Debug\TDatMitarbeiter.obj /a Build_Debug\TDatMitarbeiterBase.obj /a Build_Debug\TDatViewMitarbeiter.obj /a Build_Debug\TDatViewMitarbeiterBase.obj /a Build_Debug\TDatMontage.obj /a Build_Debug\TDatMontageBase.obj /a Build_Debug\TDatArtNotiz.obj /a Build_Debug\TDatArtNotizAnzeigenVorgabe.obj /a Build_Debug\TDatArtNotizAnzeigenVorgabeBase.obj /a Build_Debug\TDatArtNotizBase.obj /a Build_Debug\TDatArtPositionNotizTitel.obj /a Build_Debug\TDatArtPositionNotizTitelBase.obj /a Build_Debug\TDatKopfNotiz.obj /a Build_Debug\TDatKopfNotizAnzeigen.obj /a Build_Debug\TDatKopfNotizAnzeigenBase.obj /a Build_Debug\TDatKopfNotizBase.obj /a Build_Debug\TDatKopfNotizErinnerung.obj /a Build_Debug\TDatKopfNotizErinnerungBase.obj /a Build_Debug\TDatKopfNotizMitteilung.obj /a Build_Debug\TDatKopfNotizMitteilungBase.obj /a Build_Debug\TDatKopfNotizPosition.obj /a Build_Debug\TDatKopfNotizPositionBase.obj /a Build_Debug\TDatPlzZuordnung.obj /a Build_Debug\TDatPlzZuordnungBase.obj /a Build_Debug\TDatViewPlz.obj /a Build_Debug\TDatViewPlzBase.obj /a Build_Debug\TDatArtPosition.obj /a Build_Debug\TDatArtPositionBase.obj /a Build_Debug\TDatKopfPosition.obj /a Build_Debug\TDatKopfPositionBase.obj /a Build_Debug\TDatProgrammEinstellung.obj /a Build_Debug\TDatProgrammEinstellungBase.obj /a Build_Debug\TDatKopfKostenzuordnung.obj /a Build_Debug\TDatKopfKostenzuordnungBase.obj /a Build_Debug\TDatKopfKostenzuordnungDetail.obj /a Build_Debug\TDatKopfKostenzuordnungDetailBase.obj /a Build_Debug\TDatKopfKostenzuordnungDetailEigenschaftWert.obj /a Build_Debug\TDatKopfKostenzuordnungDetailEigenschaftWertBase.obj /a Build_Debug\TDatProjektuebersicht.obj /a Build_Debug\TDatProjektuebersichtBase.obj /a Build_Debug\TDatRolle.obj /a Build_Debug\TDatRolleBase.obj /a Build_Debug\TDatKopfStoerung.obj /a Build_Debug\TDatKopfStoerungBase.obj /a Build_Debug\TDatSuchbegriffMitarbeiter.obj /a Build_Debug\TDatSuchbegriffMitarbeiterBase.obj /a Build_Debug\TDatSucheMitarbeiter.obj /a Build_Debug\TDatSucheMitarbeiterBase.obj /a Build_Debug\TDatSymbol.obj /a Build_Debug\TDatSymbolBase.obj /a Build_Debug\TDatArtTermin.obj /a Build_Debug\TDatArtTerminBase.obj /a Build_Debug\TDatKopfTermin.obj /a Build_Debug\TDatKopfTerminBase.obj /a Build_Debug\TDatKopfWertTermin.obj /a Build_Debug\TDatKopfWertTerminBase.obj /a Build_Debug\TDatTermin.obj /a Build_Debug\TDatTerminBase.obj /a Build_Debug\TDatWertTermin.obj /a Build_Debug\TDatWertTerminBase.obj /a Build_Debug\TDatWechselkurs.obj /a Build_Debug\TDatWechselkursBase.obj /a Build_Debug\TDatZugang_Datenbankzugriff.obj /a Build_Debug\TDatZugang_DatenbankzugriffBase.obj /a Build_Debug\TFunktionenDatenbankzugriff.obj /a Build_Debug\TProjektdatenFuerProjektleiste.obj
    TLIB 7.1 Copyright (c) 1987-2019 Embarcadero Technologies, Inc.
    C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets104.targets(786,3): warning : Warning: library was too large for page size, rebuilt with page size 8192
Erstellen des TCPerformLink-Ziels in Projekt WolfDatenbankzugriff.cbproj beendet.
Erstellen des Projekts WolfDatenbankzugriff.cbproj beendet.
Das Erstellen war erfolgreich.
    1 Warnung(en)
    0 Fehler
Vergangene Zeit 00:00:03.56
Finished Make.
Making...
Der Buildvorgang wurde am 16.09.2020 06:33:31 gestartet.
Projekt C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\MusterProgrammVCL.cbproj (Make-Ziel(e)):
MakeObjs-Ziel:
    _PasDepCheck-Ziel:
        C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\MusterProgrammVCL.cbproj wird übersprungen
        Die Datei C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\twfiles.@@@ wird gelöscht.
    TCCompile-Ziel:
        C:\Program Files (x86)\JomiTech\TwineCompile\mtbcc32.exe -ide104 -dep -alias"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\MusterProgrammVCL.cpp"="C:\Users\CHRIST~1.ART\AppData\Local\Temp\TwineCompile\MusterProgrammVCL.cpp*1362062383"; -priority0 -files="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\twfiles.@@@"
        All files up to date. No files to compile.
Linking...
TCPerformLink-Ziel:
    c:\program files (x86)\embarcadero\studio\21.0\bin\ilink32.exe -G8 -LTmp;"c:\program files (x86)\embarcadero\studio\21.0\lib\DE\debug";"c:\program files (x86)\embarcadero\studio\21.0\lib\debug";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDateien";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionen";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDateien";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionen";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\Bin";"C:\# Entwicklung\Builder 10.2\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\Bin";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionen";"D:\#Builder XE3\Muster\Funktionen\ListUndLabel";"C:\#Builder XE3\Muster\MusterProgrammVCL\Funktionen\ListUndLabel";..\WolfDatenbankzugriff\TDat\MitarbeiterAnwesend;..\WolfDatenbankzugriff\TDat\ArtPositionOrdner;..\WolfDatenbankzugriff\TDat\Einstellung;Libs\WolfFunktionenDateien;..\WolfDatenbankzugriff\TDat\MitarbeiterGruppe;..\WolfDatenbankzugriff\TDat\ProgrammEinstellung;..\WolfDatenbankzugriff\TDat\PLZ;..\WolfDatenbankzugriff\TDat\Wechselkurs;..\WolfDatenbankzugriff\TDat\Suche;..\WolfDatenbankzugriff\TDat\Suchbegriff;..\WolfDatenbankzugriff\TDat\Auftragschance;..\WolfDatenbankzugriff\TDat\AllgText;..\WolfDatenbankzugriff\TDat\Montage;..\WolfDatenbankzugriff\TDat\Herkunft;..\WolfDatenbankzugriff\TDat\Land;..\WolfDatenbankzugriff\TDat\Adresse;..\WolfDatenbankzugriff\TDat\Anrede;..\WolfDatenbankzugriff\TDat\MitarbeiterEndgeraet;..\WolfDatenbankzugriff\TDat\Zugang;..\WolfDatenbankzugriff\TDat\MitarbeiterRechte;..\WolfDatenbankzugriff\TDat\Favoriten;..\WolfDatenbankzugriff\TDat\MitarbeiterEinstellung;..\WolfDatenbankzugriff\TDat\Mandant;..\WolfDatenbankzugriff\TDat\Art;..\WolfDatenbankzugriff\TDat\Mitarbeiter;..\WolfDatenbankzugriff\TDat\Logbuch;..\WolfDatenbankzugriff\TDat\Stoerung;..\WolfDatenbankzugriff\TDat\Symbol;..\WolfDatenbankzugriff\TDat\Projektuebersicht;..\WolfDatenbankzugriff\TDat\Arbeitszeit;..\WolfDatenbankzugriff\TDat\Liste;..\WolfDatenbankzugriff\TDat\Datei;..\WolfDatenbankzugriff\TDat\Formular;..\WolfDatenbankzugriff\TDat\Checklisten;..\WolfDatenbankzugriff\TDat\Positioin;..\WolfDatenbankzugriff\TDat\Faktura;..\WolfDatenbankzugriff\TDat\Details;..\WolfDatenbankzugriff\TDat\Auftragsaenderungen;..\WolfDatenbankzugriff\TDat\Bestellungen;..\WolfDatenbankzugriff\TDat\Kalender;..\WolfDatenbankzugriff\TDat\Termine;..\WolfDatenbankzugriff\TDat\HauptmenueProjekt;..\WolfDatenbankzugriff\TDat\Kopf;..\WolfDatenbankzugriff\TDat\Notizen;..\WolfDatenbankzugriff;Libs\WolfFunktionenListUndLabel;Libs\WolfFunktionenDatenbank;Libs\WolfFunktionen;Thread;TDat\ViewMitarbeiterRechte;TDat\MitarbeiterRolle;Funktionen\Einstellungen\TDatViewEinstellung;Funktionen\Datenbank\TDatListeBase;Funktionen\Einstellungen\TDatProgrammEinstellung;Funktionen\Grid;Funktionen\Datenbank\TDatZugang;Funktionen\Logbuch;Funktionen\Sprache\TDatPeText;Funktionen\Einstellungen\TDatMitarbeiterEinstellung;Funktionen\Einstellungen\TDatEinstellung;Funktionen\Einstellungen;TDat\Funktionen\Historie;TDat\AdresseTEST;Drucken;Funktionen\ListUndLabel;TDat;Frames;Funktionen\Sprache;TMain;Funktionen\Datenbank;Funktionen;Dialoge;"c:\program files (x86)\embarcadero\studio\21.0\lib";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release\psdk";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\xlsAdapter";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfKomponenten";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Common";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Win32\Release\Studio27";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Source\Extras";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Packages\Studio27";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfPDFTronViewer";C:\Users\Public\Documents\Embarcadero\Studio\21.0\DCP -jTmp;"c:\program files (x86)\embarcadero\studio\21.0\lib\DE\debug";"c:\program files (x86)\embarcadero\studio\21.0\lib\debug";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDateien";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionen";"C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDateien";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Libs\WolfFunktionen";"C:\# Entwicklung\Builder 10.3\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\Bin";"C:\# Entwicklung\Builder 10.2\Libs\WolfDatenbankzugriff\WolfDatenbankzugriff\Bin";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionenListUndLabel";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionenDatenbank";"C:\# Entwicklung\Builder 10.2\Muster\MusterProgrammVCL\Libs\WolfFunktionen";"D:\#Builder XE3\Muster\Funktionen\ListUndLabel";"C:\#Builder XE3\Muster\MusterProgrammVCL\Funktionen\ListUndLabel";..\WolfDatenbankzugriff\TDat\MitarbeiterAnwesend;..\WolfDatenbankzugriff\TDat\ArtPositionOrdner;..\WolfDatenbankzugriff\TDat\Einstellung;Libs\WolfFunktionenDateien;..\WolfDatenbankzugriff\TDat\MitarbeiterGruppe;..\WolfDatenbankzugriff\TDat\ProgrammEinstellung;..\WolfDatenbankzugriff\TDat\PLZ;..\WolfDatenbankzugriff\TDat\Wechselkurs;..\WolfDatenbankzugriff\TDat\Suche;..\WolfDatenbankzugriff\TDat\Suchbegriff;..\WolfDatenbankzugriff\TDat\Auftragschance;..\WolfDatenbankzugriff\TDat\AllgText;..\WolfDatenbankzugriff\TDat\Montage;..\WolfDatenbankzugriff\TDat\Herkunft;..\WolfDatenbankzugriff\TDat\Land;..\WolfDatenbankzugriff\TDat\Adresse;..\WolfDatenbankzugriff\TDat\Anrede;..\WolfDatenbankzugriff\TDat\MitarbeiterEndgeraet;..\WolfDatenbankzugriff\TDat\Zugang;..\WolfDatenbankzugriff\TDat\MitarbeiterRechte;..\WolfDatenbankzugriff\TDat\Favoriten;..\WolfDatenbankzugriff\TDat\MitarbeiterEinstellung;..\WolfDatenbankzugriff\TDat\Mandant;..\WolfDatenbankzugriff\TDat\Art;..\WolfDatenbankzugriff\TDat\Mitarbeiter;..\WolfDatenbankzugriff\TDat\Logbuch;..\WolfDatenbankzugriff\TDat\Stoerung;..\WolfDatenbankzugriff\TDat\Symbol;..\WolfDatenbankzugriff\TDat\Projektuebersicht;..\WolfDatenbankzugriff\TDat\Arbeitszeit;..\WolfDatenbankzugriff\TDat\Liste;..\WolfDatenbankzugriff\TDat\Datei;..\WolfDatenbankzugriff\TDat\Formular;..\WolfDatenbankzugriff\TDat\Checklisten;..\WolfDatenbankzugriff\TDat\Positioin;..\WolfDatenbankzugriff\TDat\Faktura;..\WolfDatenbankzugriff\TDat\Details;..\WolfDatenbankzugriff\TDat\Auftragsaenderungen;..\WolfDatenbankzugriff\TDat\Bestellungen;..\WolfDatenbankzugriff\TDat\Kalender;..\WolfDatenbankzugriff\TDat\Termine;..\WolfDatenbankzugriff\TDat\HauptmenueProjekt;..\WolfDatenbankzugriff\TDat\Kopf;..\WolfDatenbankzugriff\TDat\Notizen;..\WolfDatenbankzugriff;Libs\WolfFunktionenListUndLabel;Libs\WolfFunktionenDatenbank;Libs\WolfFunktionen;Thread;TDat\ViewMitarbeiterRechte;TDat\MitarbeiterRolle;Funktionen\Einstellungen\TDatViewEinstellung;Funktionen\Datenbank\TDatListeBase;Funktionen\Einstellungen\TDatProgrammEinstellung;Funktionen\Grid;Funktionen\Datenbank\TDatZugang;Funktionen\Logbuch;Funktionen\Sprache\TDatPeText;Funktionen\Einstellungen\TDatMitarbeiterEinstellung;Funktionen\Einstellungen\TDatEinstellung;Funktionen\Einstellungen;TDat\Funktionen\Historie;TDat\AdresseTEST;Drucken;Funktionen\ListUndLabel;TDat;Frames;Funktionen\Sprache;TMain;Funktionen\Datenbank;Funktionen;Dialoge;"c:\program files (x86)\embarcadero\studio\21.0\lib";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release\psdk";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\xlsAdapter";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfKomponenten";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Common";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Win32\Release\Studio27";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Source\Extras";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Packages\Studio27";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfPDFTronViewer";C:\Users\Public\Documents\Embarcadero\Studio\21.0\DCP -ITmp -lBin -v -Gn -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsFBD.tmp"="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Frames\frmGrid_ViewKopfGesamt.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsFCD.tmp"="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Dialoge\dlgMusterProgrammVCL.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsFBD.tmp"="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Frames\frmGrid_ViewKopfGesamt.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsFCD.tmp"="C:\# Entwicklung\Builder 10.4\Libs\WolfDatenbankzugriff\MusterProgrammVCL_Datenbankzugriff\Dialoge\dlgMusterProgrammVCL.dfm" -aa -V5.0 -Tpe c0w32 memmgr.lib sysinit.obj Tmp\MusterProgrammVCL.obj Tmp\dlgInfo.obj Tmp\dlgMemo.obj Tmp\dlgMusterProgrammVCL.obj Tmp\dlgNotizAnlegen.obj Tmp\dlgOptionen.obj Tmp\frmGrid_Adresse.obj Tmp\frmGrid_Auftragsaenderungen.obj Tmp\frmGrid_Bestellungen.obj Tmp\frmGrid_Checklisten.obj Tmp\frmGrid_Dateien.obj Tmp\frmGrid_DateiUebertragen.obj Tmp\frmGrid_Details.obj Tmp\frmGrid_Fakturiert.obj Tmp\frmGrid_Formulare.obj Tmp\frmGrid_Kontakte.obj Tmp\frmGrid_Mandanten.obj Tmp\frmGrid_Mitarbeiter.obj Tmp\frmGrid_MitarbeiterEinstellungen.obj Tmp\frmGrid_MitarbeiterEndgeraet.obj Tmp\frmGrid_Montage.obj Tmp\frmGrid_Montagelisten.obj Tmp\frmGrid_Notizen.obj Tmp\frmGrid_Projektuebersicht.obj Tmp\frmGrid_Stoerungen.obj Tmp\frmGrid_Suche.obj Tmp\frmGrid_Termine.obj Tmp\frmGrid_ViewKopfGesamt.obj Tmp\frmPosition.obj Tmp\frmSonstiges.obj Tmp\TSpracheMeldungen.obj Tmp\TAuftragsdatenFuerProjektleiste.obj Tmp\TDatenbankzugriff.obj Tmp\TDatAdresse.obj Tmp\TDatAdresseBase.obj Tmp\TDatAdresseTyp.obj Tmp\TDatAdresseTypBase.obj Tmp\TDatAllgText.obj Tmp\TDatAllgTextBase.obj Tmp\TDatArtAllgtext.obj Tmp\TDatArtAllgtextBase.obj Tmp\TDatAnrede.obj Tmp\TDatAnredeBase.obj Tmp\TDatViewArbeitszeit.obj Tmp\TDatViewArbeitszeitBase.obj Tmp\TDatArt.obj Tmp\TDatArtBase.obj Tmp\TDatKopfAenderung.obj Tmp\TDatKopfAenderungBase.obj Tmp\TDatAuftragschance.obj Tmp\TDatAuftragschanceBase.obj Tmp\TDatBestellungKopf.obj Tmp\TDatBestellungKopfBase.obj Tmp\TDatViewBestellung.obj Tmp\TDatViewBestellungBase.obj Tmp\TDatViewChecklistenPosition.obj Tmp\TDatViewChecklistenPositionBase.obj Tmp\TDatArtPositionOrdner.obj Tmp\TDatArtPositionOrdnerBase.obj Tmp\TDatDateiUebertragen.obj Tmp\TDatDateiUebertragenBase.obj Tmp\TDatThumbnail.obj Tmp\TDatThumbnailBase.obj Tmp\TDatViewDatei.obj Tmp\TDatViewDateiBase.obj Tmp\TDatFakturaDetailVerrechnet.obj Tmp\TDatFakturaDetailVerrechnetBase.obj Tmp\TDatKonzernEinstellung.obj Tmp\TDatKonzernEinstellungBase.obj Tmp\TDatViewFakturaUebersicht.obj Tmp\TDatViewFakturaUebersichtBase.obj Tmp\TDatZahlungseingang.obj Tmp\TDatZahlungseingangBase.obj Tmp\TDatFavoriten.obj Tmp\TDatFavoritenBase.obj Tmp\TDatKopfPositionFormular.obj Tmp\TDatKopfPositionFormularBase.obj Tmp\TDatWertFormular.obj Tmp\TDatWertFormularBase.obj Tmp\TDatHauptmenueProjekt.obj Tmp\TDatHauptmenueProjektBase.obj Tmp\TDatHerkunft.obj Tmp\TDatHerkunftBase.obj Tmp\TDatKalender.obj Tmp\TDatKalenderArt.obj Tmp\TDatKalenderArtBase.obj Tmp\TDatKalenderBase.obj Tmp\TDatKopf.obj Tmp\TDatKopfBase.obj Tmp\TDatViewKopfFreigabe.obj Tmp\TDatViewKopfFreigabeBase.obj Tmp\TDatViewKopfGesamt.obj Tmp\TDatViewKopfGesamtBase.obj Tmp\TDatViewKopfGesamt_Duplikatssuche.obj Tmp\TDatViewKopfGesamt_DuplikatssucheBase.obj Tmp\TDatViewLand.obj Tmp\TDatViewLandBase.obj Tmp\TDatViewMontagelisten.obj Tmp\TDatViewMontagelistenBase.obj Tmp\TDatLogbuch_Datenbankzugriff.obj Tmp\TDatLogbuch_DatenbankzugriffBase.obj Tmp\TDatMandant.obj Tmp\TDatMandantBase.obj Tmp\TDatViewMitarbeiterAnwesend.obj Tmp\TDatViewMitarbeiterAnwesendBase.obj Tmp\TDatMitarbeiterEinstellung_Datenbankzugriff.obj Tmp\TDatMitarbeiterEinstellung_DatenbankzugriffBase.obj Tmp\TDatMitarbeiterEndgeraet.obj Tmp\TDatMitarbeiterEndgeraetBase.obj Tmp\TDatMitarbeiterGruppeLetzteNr.obj Tmp\TDatMitarbeiterGruppeLetzteNrBase.obj Tmp\TDatMitarbeiterGruppeMitglieder.obj Tmp\TDatMitarbeiterGruppeMitgliederBase.obj Tmp\TDatPE_MitarbeiterZuRecht.obj Tmp\TDatPE_MitarbeiterZuRechtBase.obj Tmp\TDatViewMitarbeiterRechte_Datenbankzugriff.obj Tmp\TDatViewMitarbeiterRechte_DatenbankzugriffBase.obj Tmp\TDatKontakteSuchen.obj Tmp\TDatKontakteSuchenBase.obj Tmp\TDatMitarbeiter.obj Tmp\TDatMitarbeiterBase.obj Tmp\TDatViewMitarbeiter.obj Tmp\TDatViewMitarbeiterBase.obj Tmp\TDatMontage.obj Tmp\TDatMontageBase.obj Tmp\TDatArtNotiz.obj Tmp\TDatArtNotizAnzeigenVorgabe.obj Tmp\TDatArtNotizAnzeigenVorgabeBase.obj Tmp\TDatArtNotizBase.obj Tmp\TDatArtPositionNotizTitel.obj Tmp\TDatArtPositionNotizTitelBase.obj Tmp\TDatKopfNotiz.obj Tmp\TDatKopfNotizAnzeigen.obj Tmp\TDatKopfNotizAnzeigenBase.obj Tmp\TDatKopfNotizBase.obj Tmp\TDatKopfNotizErinnerung.obj Tmp\TDatKopfNotizErinnerungBase.obj Tmp\TDatKopfNotizMitteilung.obj Tmp\TDatKopfNotizMitteilungBase.obj Tmp\TDatKopfNotizPosition.obj Tmp\TDatKopfNotizPositionBase.obj Tmp\TDatPlzZuordnung.obj Tmp\TDatPlzZuordnungBase.obj Tmp\TDatViewPlz.obj Tmp\TDatViewPlzBase.obj Tmp\TDatArtPosition.obj Tmp\TDatArtPositionBase.obj Tmp\TDatKopfPosition.obj Tmp\TDatKopfPositionBase.obj Tmp\TDatProgrammEinstellung.obj Tmp\TDatProgrammEinstellungBase.obj Tmp\TDatKopfKostenzuordnung.obj Tmp\TDatKopfKostenzuordnungBase.obj Tmp\TDatKopfKostenzuordnungDetail.obj Tmp\TDatKopfKostenzuordnungDetailBase.obj Tmp\TDatKopfKostenzuordnungDetailEigenschaftWert.obj Tmp\TDatKopfKostenzuordnungDetailEigenschaftWertBase.obj Tmp\TDatProjektuebersicht.obj Tmp\TDatProjektuebersichtBase.obj Tmp\TDatKopfStoerung.obj Tmp\TDatKopfStoerungBase.obj Tmp\TDatSuchbegriffMitarbeiter.obj Tmp\TDatSuchbegriffMitarbeiterBase.obj Tmp\TDatSucheMitarbeiter.obj Tmp\TDatSucheMitarbeiterBase.obj Tmp\TDatSymbol.obj Tmp\TDatSymbolBase.obj Tmp\TDatArtTermin.obj Tmp\TDatArtTerminBase.obj Tmp\TDatKopfTermin.obj Tmp\TDatKopfTerminBase.obj Tmp\TDatKopfWertTermin.obj Tmp\TDatKopfWertTerminBase.obj Tmp\TDatTermin.obj Tmp\TDatTerminBase.obj Tmp\TDatWertTermin.obj Tmp\TDatWertTerminBase.obj Tmp\TDatWechselkurs.obj Tmp\TDatWechselkursBase.obj Tmp\TDatZugang_Datenbankzugriff.obj Tmp\TDatZugang_DatenbankzugriffBase.obj Tmp\TFunktionenDatenbankzugriff.obj Tmp\TProjektdatenFuerProjektleiste.obj , Bin\MusterProgrammVCL.exe , Bin\MusterProgrammVCL.map , vcl.lib rtl.lib dbrtl.lib adortl.lib vclimg.lib xmlrtl.lib vclactnband.lib vclx.lib VclSmp.lib vcldb.lib IndyProtocols.lib IndyCore.lib IndySystem.lib DbxCommonDriver.lib dsnap.lib fmx.lib FireDACCommon.lib FireDACCommonDriver.lib FireDACODBCDriver.lib FireDACMSSQLDriver.lib FireDAC.lib FireDACSqliteDriver.lib vclFireDAC.lib FireDACCommonODBC.lib inet.lib vclie.lib soaprtl.lib WolfKomponenten.lib vclwinx.lib TMSVCLUIPackPkgDXE13.lib TMSVCLUIPackPkgExDXE13.lib WolfFunktionenDateien.lib WolfFunktionenDatenbank.lib WolfFunktionen.lib import32.lib cp32mt.lib , , MusterProgrammVCL.res MusterProgrammVCL.res
    C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets104.targets(786,3): error : Error: RLINK32: Error opening file "C:\# ENTWICKLUNG\BUILDER 10.4\LIBS\WOLFDATENBANKZUGRIFF\MUSTERPROGRAMMVCL_DATENBANKZUGRIFF\DLGMUSTERPROGRAMMVCL.DFM"
Erstellen des TCPerformLink-Ziels in Projekt MusterProgrammVCL.cbproj beendet - Fehler beim Erstellen.
Erstellen des Projekts MusterProgrammVCL.cbproj beendet - Fehler beim Erstellen.
    0 Warnung(en)
    1 Fehler
Vergangene Zeit 00:00:41.19
Finished Make.
Posted: Mon Sep 21, 2020 11:27 pm
by Chris
Any updates on this?
Posted: Tue Sep 22, 2020 5:34 pm
Sorry for the delay in responding. We're still trying to replicate this issue - seems to be related to the static library creation for a package. Are you only seeing this with package builds, or it occurs with an application project as well?
Posted: Wed Sep 23, 2020 12:07 am
by Chris
It also occurs on normal Projects/Applications. If needed, i can post a Log of this as well.
I don't know if it can have an effect on this, but we are NOT linking with Runtime Packages in all of our Projects.
Posted: Wed Sep 23, 2020 12:30 am
by Chris
Here's another log from a small Project:
Making...
Der Buildvorgang wurde am 23.09.2020 07:19:13 gestartet.
Projekt C:\# Entwicklung\Builder 10.4\PE\PEKunde\PEKunde.cbproj (Make-Ziel(e)):
MakeObjs-Ziel:
    _PasDepCheck-Ziel:
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\PEKunde.cbproj wird übersprungen
        Die Datei C:\# Entwicklung\Builder 10.4\PE\PEKunde\twfiles.@@@ wird gelöscht.
    TCCompile-Ziel:
        C:\Program Files (x86)\JomiTech\TwineCompile\mtbcc32.exe -ide104 -dep -alias"C:\# Entwicklung\Builder 10.4\PE\PEKunde\PEKunde.cpp"="C:\Users\CHRIST~1.ART\AppData\Local\Temp\TwineCompile\PEKunde.cpp*1361533348"; -priority0 -files="C:\# Entwicklung\Builder 10.4\PE\PEKunde\twfiles.@@@"
        Compiling 2 files...
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp
        dlgPEKunde.cpp: (0) 0 of 0
        Vorcompilierte Header geladen
        TDat\TDatAdresse.h(103,87): C++ warning W8022: 'TDatAdresseMapper::UpdateDat(TDatAdresse *)' verbirgt virtuelle Funktion 'TDatAdresseMapperBase::UpdateDat(TDatAdresse *,UnicodeString)'
        C:\# Entwicklung\Builder 10.4\# Komponenten\WolfKomponenten\TWolfGrid.h(130,18): C++ warning W8118: Inline-Member-Funktion in Package-Klasse
        dlgPEKunde.cpp: (0) 289836 of 289836
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(122,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(160,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(160,1): C++ warning W8057: Parameter 'Action' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(199,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(276,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(282,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(297,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(302,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(310,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(316,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.cpp(329,1): C++ warning W8057: Parameter 'Sender' wird nie verwendet
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\TDat\TDatAdresse.cpp
        TDatAdresse.cpp: (0) 0 of 291295
        TDatAdresse.cpp: (0) 1443072 of 1734367
        C:\# Entwicklung\Builder 10.4\PE\PEKunde\TDat\TDatAdresse.h(103,87): C++ warning W8022: 'TDatAdresseMapper::UpdateDat(TDatAdresse *)' verbirgt virtuelle Funktion 'TDatAdresseMapperBase::UpdateDat(TDatAdresse *,UnicodeString)'
        Compiled 2 files in 2,21 secs.
    Erstellen des TCCompile-Ziels in Projekt PEKunde.cbproj beendet.
Erstellen des MakeObjs-Ziels in Projekt PEKunde.cbproj beendet.
Linking...
TCPerformLink-Ziel:
    c:\program files (x86)\embarcadero\studio\21.0\bin\ilink32.exe -G8 -Ltmp;"c:\program files (x86)\embarcadero\studio\21.0\lib\Win32\release\DE";Funktionen\Dateien;Threads;TDat\Funktionen\Logbuch;TDat;TDatBase;Funktionen\Sprache;Funktionen\Datenbank;Funktionen;Frames\Verhalten;Frames;TMain;Dialoge;"c:\program files (x86)\embarcadero\studio\21.0\lib";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release\psdk";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\xlsAdapter";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfKomponenten";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Common";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Win32\Release\Studio27";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Source\Extras";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Packages\Studio27";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfPDFTronViewer";C:\Users\Public\Documents\Embarcadero\Studio\21.0\DCP;Debug_Build -jtmp;"c:\program files (x86)\embarcadero\studio\21.0\lib\Win32\release\DE";Funktionen\Dateien;Threads;TDat\Funktionen\Logbuch;TDat;TDatBase;Funktionen\Sprache;Funktionen\Datenbank;Funktionen;Frames\Verhalten;Frames;TMain;Dialoge;"c:\program files (x86)\embarcadero\studio\21.0\lib";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release";"c:\program files (x86)\embarcadero\studio\21.0\lib\win32\release\psdk";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL WebGMaps\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\Delphi104Sydney\Win32\Release";"C:\Users\christian.artinger\Documents\tmssoftware\TMS VCL UI Pack\xlsAdapter";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfKomponenten";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Common";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Lib\Win32\Release\Studio27";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Source\Extras";"C:\Program Files (x86)\Neos Eureka S.r.l\EurekaLog 7\Packages\Studio27";"C:\# Entwicklung\Builder 10.4\# Komponenten\WolfPDFTronViewer";C:\Users\Public\Documents\Embarcadero\Studio\21.0\DCP;Debug_Build -ITmp -lBin -v -Gn -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF63B.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Frames\frmKunde.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF63C.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Frames\frmKundeSuche.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF64D.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF63B.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Frames\frmKunde.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF63C.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Frames\frmKundeSuche.dfm" -GA"C:\Users\CHRIST~1.ART\AppData\Local\Temp\vfsF64D.tmp"="C:\# Entwicklung\Builder 10.4\PE\PEKunde\Dialoge\dlgPEKunde.dfm" -aa -V5.0 -Tpe c0w32 memmgr.lib sysinit.obj tmp\PEKunde.obj tmp\dlgBescheinigungEdit.obj tmp\dlgBescheinigungVorauswahl.obj tmp\dlgKoordinatenManuell.obj tmp\dlgKundeDaten.obj tmp\dlgKundeGeaendert.obj tmp\dlgOptionen.obj tmp\dlgPEKunde.obj tmp\frmAnsprechperson.obj tmp\frmAnsprechpersonDaten.obj tmp\frmBescheinigungen.obj tmp\frmGrid.obj tmp\frmKunde.obj tmp\frmKundeDaten.obj tmp\frmKundeKfm.obj tmp\frmKundeSuche.obj tmp\TFrmGrid.obj tmp\TFrmGridBescheinigungen.obj tmp\TFrmGridHistorie.obj tmp\TDropTarget.obj tmp\TFunktionenDateien.obj tmp\WolfDataObject.obj tmp\DataModul.obj tmp\TDataStore.obj tmp\TElement.obj tmp\TSprache.obj tmp\TSpracheMeldungen.obj tmp\TSpracheMeldungenBase.obj tmp\TUebersetzungen.obj tmp\TEinstellungen.obj tmp\TFunktionen.obj tmp\TFunktionenMeldung.obj tmp\TDatAdresseBase.obj tmp\TDatAdresseBescheinigungBase.obj tmp\TDatAdresseBescheinigungDateiBase.obj tmp\TDatAdresseTypBase.obj tmp\TDatAnredeBase.obj tmp\TDatAnsprechpersonBase.obj tmp\TDatBescheinigungBase.obj tmp\TDatHistorieBase.obj tmp\TDatLieferartBase.obj tmp\TDatLieferbedingungBase.obj tmp\TDatLogbuchBase.obj tmp\TDatPlzBase.obj tmp\TDatPreislisteBase.obj tmp\TDatViewLandBase.obj tmp\TDatViewMitarbeiterBase.obj tmp\TDatViewMitarbeiterRechteBase.obj tmp\TDatZahlungsartBase.obj tmp\TDatZahlungsbedingungBase.obj tmp\TDatLogbuch.obj tmp\TDatAdresse.obj tmp\TDatAdresseBescheinigung.obj tmp\TDatAdresseBescheinigungDatei.obj tmp\TDatAdresseTyp.obj tmp\TDatAnrede.obj tmp\TDatAnsprechperson.obj tmp\TDatBescheinigung.obj tmp\TDatHistorie.obj tmp\TDatLieferart.obj tmp\TDatLieferbedingung.obj tmp\TDatPlz.obj tmp\TDatPreisliste.obj tmp\TDatViewLand.obj tmp\TDatViewMitarbeiter.obj tmp\TDatViewMitarbeiterRechte.obj tmp\TDatZahlungsart.obj tmp\TDatZahlungsbedingung.obj tmp\TThreadUebergabeSidoun.obj tmp\TMain.obj , Bin\PEKunde.exe , Bin\PEKunde.map , vcl.lib rtl.lib dbrtl.lib adortl.lib vclx.lib xmlrtl.lib IndyProtocols.lib IndyCore.lib IndySystem.lib bcbie.lib DbxCommonDriver.lib dsnap.lib inet.lib vclie.lib vclimg.lib WolfKomponenten.lib vclactnband.lib vcldb.lib VclSmp.lib soaprtl.lib TMSWebGMapsPkgDXE13.lib vcledge.lib TMSVCLUIPackPkgDXE13.lib vclwinx.lib TMSVCLUIPackPkgExDXE13.lib import32.lib cp32mt.lib , , PEKunde.res Funktionen\Allgemein\SortIcons.res PEKunde.res
    C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets104.targets(786,3): error : Error: RLINK32: Error opening file "C:\# ENTWICKLUNG\BUILDER 10.4\PE\PEKUNDE\DLGPEKUNDE.DFM"
Erstellen des TCPerformLink-Ziels in Projekt PEKunde.cbproj beendet - Fehler beim Erstellen.
Erstellen des Projekts PEKunde.cbproj beendet - Fehler beim Erstellen.
    14 Warnung(en)
    1 Fehler
Vergangene Zeit 00:00:11.58
Finished Make.
I also tried to reproduce it with a little simple Program (one form, one class), but had no luck either with it to reproduce it.
What i did in our Application above:
I opened a form and a normal class. I did changes on both of thes (first on the form, then on the class). That's it, the error occurs (also not every time, but in about 3 of 5 times).
Posted: Wed Sep 23, 2020 6:48 pm
Can you try turning OFF the option to Compile Projects/Files without saving them? It's located under the TwineCompile options (the Plugin section)
