Unknown type name errors when using TC 5.1 on RS 10.3.3 with bcc32c
Posted: Sat May 23, 2020 9:37 am
by DeveloperAcstre
I have a problem compiling with TwineCompile 5.1 under Rad Studio 10.3.3 using the clang compiler. I am able to reproduce the problem in a demo project.
- Test.zip
- (9.18 KiB) Downloaded 4775 times
Lets say i have a unit with one declaration in the header file:
I do not include the
String header file in that unit because i included it in the precompiled header. If i try to compile it gives me an error saying
"Unknown type name 'String'". It should find the declaration in the precompiled header. If i try to build it again without doing any changes it compiles fine. But if i Clean the project and try to compile it again the same error appears.
The error is happening only when using twine compile.
Best regards!
Re: Unknown type name errors when using TC 5.1 on RS 10.3.3 with bcc32c
Posted: Mon May 25, 2020 8:56 pm
Are you compiling just this unit, or does the problem appear when doing a Build or Make of the entire project?
Posted: Tue May 26, 2020 5:30 am
by DeveloperAcstre
It appears when i am doing Build or Make of the entire project.
Posted: Tue May 26, 2020 9:19 pm
Please download the attached file and extract it into the TwineCompile Program Files directory to resolve this issue.
Posted: Wed May 27, 2020 1:54 pm
by DeveloperAcstre
I am getting this error:
[MSBuild Error] TCTargets103.targets(115, 5): MSB4036 The "TCInitTasks" task was not found. Check the following: 1.) The name of the task in the project file is the same as the name of the task class. 2.) The task class is "public" and implements the Microsoft.Build.Framework.ITask interface. 3.) The task is correctly declared with <UsingTask> in the project file, or in the *.tasks files located in the "C:\Windows\Microsoft.NET\Framework\v4.0.30319" directory.
Posted: Wed May 27, 2020 6:00 pm
Sorry about that, that included another fix. Can you download the latest build of TwineCompile and install it?
Posted: Wed May 27, 2020 7:15 pm
by DeveloperAcstre
The latest version works fine, thanks.
C++ Builder 10.4 is released will Twine Compile support it soon?
Posted: Wed May 27, 2020 7:22 pm
Yes, 5.2 with support for 10.4 will be out soon
