Increase "cancellation pipe" Count?
Posted: Wed Apr 08, 2015 1:56 pm
Is there an option anywhere to increase the number of "pipe instances"?
We've mostly run into this issue when we have two compiles that are linking and we try to start a third. The third will report the error instead of compiling. I assume that linking holds onto these pipe instances longer than is desired. It is potentially a big issue on a large build automation server where many builds may be running concurrently all sharing the TwineCompile "farm".
Thanks,
Ben
JomiTech TwineCompile 4.1 - Copyright JomiTech 2014. All Rights Reserved.
Couldn't compile files. Message: Can't create cancellation pipe: (E7) All pipe instances are busy.
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargetsXE7.targets(614,5): error MSB6006: "mtbcc32" exited with code 1.
Ben
