obj getting bigger
Posted: Sat Dec 08, 2012 6:40 am
by TKrauss
In our project there is always after few compiles and links the "fatal error: out of memory".
Now I noticed that if obj are recompiled with Twine Compile they are bigger than before...
The only thing that I can do is, to kill the processes "mtbcc32compilerexecutor" after each compilation. Then the obj files stay at their sizes on recompilation!
Re: obj getting bigger
Posted: Mon Dec 10, 2012 9:06 am
That is very interesting. bcc must be caching some internal state that keeps on being added to the obj files as they're compiled. Is this XE3?
Posted: Tue Dec 11, 2012 12:42 pm
by TKrauss
No we currently using XE2!
Posted: Thu Dec 13, 2012 9:48 am
I'll have to see if I can reproduce it, and if not, and I know this will be hard, could you come up with a test case for this issue? Most likely, there's a cpp file that you're compiling that is causing bcc32 to act this way.
Posted: Thu Jan 17, 2013 4:11 pm
by TKrauss
Did you had any success? What is the status of this issue?
Thank you!
Posted: Mon Jan 21, 2013 9:02 am
I was not able to reproduce this issue. Would there be any chance of your putting together a test case?
