Since XE2 there is an extra compilation of all units for static libraries.
This compilation doesn't use TwineCompile bcc32 is executed there. Is there any possibility to compile the "static compilation" with TwineCompile?
We use the version 3.3.1 under XP!
Static libraries
Re: Static libraries
Is this extra compilation part of the normal Make or Build, or is it a separate command?
This happens if I activate the option: "Generate static package library" under "C++ Linker"!
Are there any news to tell?
Can you build the package and provide the entire contents of the TwineCompile Console Output? In my tests the static library was correctly handled via TwineCompile.
Sorry for the late response.
As you can see in the log-attachment not mtbcc32 is startet for compilation in static execution.
There is bcc32 used for compilation which is very slow!
- Attachments
- TwineCompile_StaticLog.zip
- (940 Bytes) Downloaded 3065 times
That was just the tail.
At first compilation (the one which creates the "dynamic" objects use mtbcc32) only the second (the static objects) is not using mtbcc32.exe it uses bcc32.exe instead.
Can you provide the entire log? You can send it to support at jomitech dot com.
