Unable to rename filename.$$$ to filename.h
Posted: Thu Mar 29, 2012 4:58 am
when enabling SORTA with twinecompile 3.3 I very often get the following error:
Unable to rename 'c:\path\filename.$$$' to 'c:\path\filename.h'. This always occurs when sorta compile is running and I try to save a modified file in builder.
I then have to go to that file in Windows explorer and change the extension back to .h (or .cpp). So it happens for headers and cpp files.
I mostly disable sorta to avoid this error, but I would rather see this fixed so I can re-enable sorta
Thanks,
Steven
Thanks,
Steven
