TC on Win7 much more slower than on XP
Posted: Tue Dec 20, 2011 5:10 pm
I tested now TwineCompile under Windows 7 x86. There I noticed that although I have 2 Cores more and a SSD in Windows 7 the compilation lasts 10 Minutes more than under XP!
Is there any way to get at least the same reults?
Brgds,
Thorsten
Re: TC on Win7 much more slower than on XP
Posted: Tue Dec 20, 2011 5:23 pm
How many threads are you using, and how many files compile at the same time (you can see the files in the compile window)?
Posted: Wed Dec 21, 2011 6:59 am
On the Windows 7 machine I use 4 Threads and they are all used.
On the Windows XP machine I only use 4 Threads and there the compilation is much more faster with half CPU power?!?
Posted: Wed Dec 21, 2011 10:07 am
If you're only using 4 threads on the Win 7 machine, and it has two cores more, you're wasting CPU
Up that to 6 threads.
Couple questions:
- What are the processors in the XP and 7 machines?
- What anti-virus/anti-malware software do you use in both machines?
- Are you running inside a VM?
- Is either machine a laptop?
Posted: Wed Dec 21, 2011 2:30 pm
I don't run anything in a vm...
Win7 x86 desktop:
- Phenom 905e (4x2.5GHz)
- SSD SATA3
- 1333MHz DDR3 4GByte
- NOD32
=> Duration: 39 Minutes!
WinXP x86 desktop:
- Core 2 Duo (2x3.16GHz)
- HDD SATA2
- 800 MHz DDR2 3.5GByte
- McAffee
=> Duration: 27 Minutes!
Both Anti-Virus are configured to exclude all files in the folders which will be touched by compiler/linker!
Posted: Thu Feb 02, 2012 12:39 pm
Are there any news why TC is slower under Win7?
Or do I have to contact Embarcadero?
Posted: Thu Feb 02, 2012 1:18 pm
Do you see this difference if you turn TC off?
Posted: Mon Feb 06, 2012 12:49 pm
No without TC I don't notice any difference in speed.
I made some tests and the result is, that with only two threads (I changed this in IDE and run over jtmake) the compilation is 4 minutes faster?!?
So with 4 threads it lasts 39 minutes and with 2 threads it only lasts 34 minutes for compilation. How can that be?
I have a real quad core cpu so no hyperthreading...
Posted: Wed Feb 08, 2012 8:26 am
What happens if you turn off the AV completely?
Posted: Thu Feb 09, 2012 7:22 am
What do you mean with AV?
