TwineCompile with MSbuild, but not with IDE
zzattack
Re: TwineCompile with MSbuild, but not with IDE
Post by zzattack »
Awesome, thanks. Which property does -prog- map to? Far as I can tell this is undocumented still. If not, where should I be looking?
It's not published as an MSBuild property out of the box, so you need to make some tweaks to make it available. The easiest way is to modify TCTargets104.targets to add it directly to the TCCompileFileList task.
For example:
<TCCompileFileList
Condition="('$(FileToCompile)'=='' Or '$(TCChildBuild)'!='true') And '$(TC_HasFiles)'=='True'"
Threads="$(TC_Threads)"
DisableCaching="$(TC_DisableCaching)"
InjectHeader="$(BCC_PCHInject)"
AllocateFiles="$(TC_AllocateFiles2)"
StopOnErrors="$(TC_StopOnErrors)"
FileAliases="$(TC_FileAliases)"
Make="$(TC_Make)"
Priority="$(TC_Priority)"
Affinity="$(TC_Affinity)"
MaxCache="$(TC_MaxCache)"
PermanentCache="$(TC_PCache)"
ProjectDirectory="$(MSBuildProjectDirectory)"
UseClang="$(USING_CLANG)"
DisableProgress="$(TC_DisableProgress)"
And then you can invoke the compile and set the TC_DisableProgress property to true or false.
zzattack
Post by zzattack »
Excellent, thank you, works perfectly. I noticed multiple TCCompileFileList entries in this XML, simply adding the DisableProgress attribute to each did the trick.
I hope this will become available by default in the Targets file, as I can see myself overwriting this file with new installers without realizing it.
zzattack
Post by zzattack »
This no longer appears to work with the TcTargets110.targets file. Do we have to change something?
Unfortunately, we removed the -prog- flag from the MSBuild action because we thought it was not being used any longer. We'll add it back in the next release and make it part of the targets files as well.
