RLINK32 Error opening File "C:\...\*.dfm"
Chris
Re: RLINK32 Error opening File "C:\...\*.dfm"
Post by Chris »
I turned the setting off, looks good so far!
Interesting. Hopefully it is an acceptable workaround. Still haven't had any luck reproducing the issue.
Chris
Post by Chris »
I would prefer it the other way. But the important thing is, that it works now and it does :-)
I also tried to reproduce it in a sample project, but had no luck (maybe the error only occurs if the project is a little bit bigger). I try to investigate further in it to provide you a "working" example, when i have time for it.
I have a fix that may solve this issue. Please download the following file and extract it into the TwineCompile Program Files directory.
http://jomitech.com/downloads/JTBuildInterface104.zip
Chris
Post by Chris »
Thank you! I'll give it a try and let you know!
Chris
Post by Chris »
Unfortunately this didn't solved the problem :-(
