Page 2 of 2
Re: Seattle command line build
Posted: Thu Jan 10, 2019 5:56 pm
You should no longer need this special task in TwineCompile 5.0. The Borland assemblies are automatically pulled in from the correct location. Give it a try, if it doesn't work, post back here.
Posted: Fri Jan 11, 2019 2:30 am
by Nitro
I do not have version 5.0 and the trial version does not work anymore on my computer. The person who contacted me (peek) was testing version 5.0. She had the problem.
Posted: Fri Jan 11, 2019 9:00 am
That is interesting. There must be some specific setup difference that's causing the issue. Can you ask her to post here or send a support request to support@jomitech.com?
Posted: Mon Jan 14, 2019 4:32 am
by Nitro
I passed the message. I hope he gets back to you.
Posted: Wed Jan 16, 2019 8:20 am
by peek
Hi !
I was using the trial version of first 4.5 and then the 5.0 version.
To evaluate if we could use it in our build environment.
With the 5.0 version I could not use the MSbuild solution straight away.
I had to implement the task that Nitro has suggested.
Since we already had a .dll for the BuildTasks it was not that big a deal.
But I did not know how to use the task.
Luckily Nitro explained to me.
We will most likely buy a number of licenses for our build servers and some of our developers soon.
But I will need to do some more testing.
I will get back on if 5.0 work out of the box next week.
Best Regards
/Per Eklund
