Unknown type name errors when using TC 5.1 on RS 10.3.3 with bcc32c
DeveloperAcstre
Post by DeveloperAcstre »
I have a problem compiling with TwineCompile 5.1 under Rad Studio 10.3.3 using the clang compiler. I am able to reproduce the problem in a demo project.
Test.zip
(9.18 KiB) Downloaded 4824 times
Lets say i have a unit with one declaration in the header file:
String test();
I do not include the String header file in that unit because i included it in the precompiled header. If i try to compile it gives me an error saying "Unknown type name 'String'". It should find the declaration in the precompiled header. If i try to build it again without doing any changes it compiles fine. But if i Clean the project and try to compile it again the same error appears.
The error is happening only when using twine compile.
Best regards!
Re: Unknown type name errors when using TC 5.1 on RS 10.3.3 with bcc32c
Are you compiling just this unit, or does the problem appear when doing a Build or Make of the entire project?
DeveloperAcstre
It appears when i am doing Build or Make of the entire project.
Please download the attached file and extract it into the TwineCompile Program Files directory to resolve this issue.
TCTargets103.zip
(7.13 KiB) Downloaded 5540 times
DeveloperAcstre
I am getting this error:
[MSBuild Error] TCTargets103.targets(115, 5): MSB4036 The "TCInitTasks" task was not found. Check the following: 1.) The name of the task in the project file is the same as the name of the task class. 2.) The task class is "public" and implements the Microsoft.Build.Framework.ITask interface. 3.) The task is correctly declared with <UsingTask> in the project file, or in the *.tasks files located in the "C:\Windows\Microsoft.NET\Framework\v4.0.30319" directory.
Sorry about that, that included another fix. Can you download the latest build of TwineCompile and install it?
DeveloperAcstre
The latest version works fine, thanks.
C++ Builder 10.4 is released will Twine Compile support it soon?
Yes, 5.2 with support for 10.4 will be out soon
